That unit is suppose to have electronic quartz igniters. Apparently there's a problem but it doesn't automatically mean the igniter needs to be replaced. If you see a spark from the igniter then it's fine. If you see a spark but no flame then the ignition process is out of synchronization. In other words, the gas hasn't concentrated near the spark enough to ignite. This may be a matter of low gas pressure or the extra length the gas needs to flow to reach the center burner is impeding ignition. Simple fix is turn the knob just enough to start the gas for 2 seconds then continue the turn to click the igniter. or simply use a match. You may also see if there are any adjustments on the gas manifold that will enhance bringing more gas to the center burner quicker. Some unit have one click & that's it, others click the igniter continuously until you release turning the knob. Good luck. you'll figure it out.
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
I have a stove that doesn't light (click) I've replaced the igniters, I've replaced the knobs, and I've replace the box all the igniters and plugged into. There's nothing else to change out and it still doesn't give a spark. I've got gas and electricity but nothing will light
Hi, you probably got water under the cooktop while cleaning around the knobs. It causes a short at the 120 volt igniter switches on the shaft of each valve. Unplug the stove for 1 or 2 day and let it dry.
Your problem is a stuck igniter switch or a bad spark module. Each surface valve has its own igniter switch. Turn off the gas. Remove the panel covering the valves to access the switches. With the gas OFF,turn on all surface switches. Move the dial past the LITE setting. The switches should still be making the sparking sound. Remove one wire at a time from each surface switch. When the sparking stops,that last switch with the wire removed will be the bad switch. The one that needs replacing. If you do not find a bad switch the main spark control module will have to be replaced. Part # 71003385 Igniter switch. Part # 71002783 Spark module. Occasionally a igniter switch becomes dislodged from the correct position and can be re-seated. Look at the position of all switches before you do any test. Make sure they are all seated.
