Bosch SHE4AP06UC Dishwasher Logo
Anonymous Posted on Nov 22, 2010
New Bosch Ascenta dishwasher - motor drive @10kHz produces unbearable high-pitched whine.
  • Anonymous Aug 27, 2012
    I am on my second Bosch Ascenta from Lowes. Same very high pitched noise but not in the rinse cycle. These units are both right out of the box and as soon as you start a cycle ie test for leaks from installation the noise starts. Seems to be more of an electronic noise rather than a bearing failure or impeller debris noise. These 3 solutions don't seem to apply since I haven't run any dishes through them yet!
dave gill
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 06, 2014
dave gill
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
249
Points
The 10KHz noise you here is from the motor drive circuit that feeds the motor on the right side close to the front. I placed a near field probe all around the DW and determined that there are significant emissions coming from this area. What does this mean? It means that the circuit was not designed properly. Experience leads me to believe that it may not cause physical damage but it can be corrected and Bosch needs to do so. I prepared a report for them. Rest assured this is not related to a bearing or the actual movement of a mechanical device, like a motor. It is caused by the circuit that makes the motor move.
4 Related Answers
Anonymous
  • 11 Answers
  • Posted on Jan 15, 2009
SOURCE: Dishwasher Making Loud High Pitched Noise.
A loud high pitch whine while running the dishwasher means that there is something caught in the chopper assembly. To get to the chopper assembly you need to take the racks out and take the pump apart from the inside of the dishwasher. The chopper assembly looks like a metal grate with holes in it. And it might not even be stuck in the grate but somewhere in the pump area due to the water being pumped out, so the best idea is to take the whole thing apart and clean everywhere. However I do not recommend doing this unless you are completely certain you will remember where the screws and gaskets go, otherwise you risk damaging your pump or house from a leak or improper installation. You have been warned.
A
Anonymous
  • Posted on Sep 24, 2008
Problem is with the main pump motor bearing. Water leaking from the face seal enters the front bearing. After some time, the bearing wears out bringing on the loud noise. The motor is easy to remove but the bearing requires some time to remove. I did not have access to a press so I ground off the bearing an replaced it with a shielded 8mmx22mm type. Grainger p/n 1L001. The part is only $9 compared to over $200 for a replacement motor. It takes some time and disassembly of the dishwasher can be difficult but take your time and be ginger with the parts. The root of the problem seems to be the impeller. It screws onto the motor shaft and seems to work loose after time. Since its tightness compresses the face seal, when it loosens water can seep. No way to lock it in place after tightening. Weak design point.
Anonymous
  • 640 Answers
  • Posted on Feb 24, 2008
How deep do you want to get into this?It sounds like the wash pump motor bearings that are worn.You can pull the unit out flip it over and wd40 the bearings in the motor or you can replace the bearings.Try to lube them first.
Anonymous
  • 27 Answers
  • Posted on Mar 13, 2009
SOURCE: Bosch dishwasher whining
if you listen to the appliance and the noise is louder on the rhs and low down this is probably the main wash motor they sometimes do whine if you can live with the noise leave it alone if not you basically have to take the whole applianmce apart for access to the motor costly repair would take a trained pro about 90 mins to replace the motor
if the noise is coming from the front of the appliance more to the lhs and is intermittant ie when it first starts up and then about half way through its likely to be the drain pump relitively easy to replace and you dont have to take the appliance to bits just go at from the front
good luck
S107 RC Helicopter making a high pitched whine when used
If the gears are meshing properly and the rotors are not spinning very fast then the motor shaft is slipping in the hub of the first gear.
1helpful
As soon as the motor starts up after the dishwasher fills, the motor makes a loud grinding noise that turns into high pitch whining. Water begins leaking from above the pump.
That shows a leaking water seal. Water would run into the motor bearings which then rust and make noise. You probably need the motor / pump kit.
May 20, 2011 • Dishwashers
Bosch dishwasher has high pitched squealing noise when it is filing
A high-pitched sound which occurs when filling is usually cavitation - air in the water valve causes a kind of "squeal". It's relatively harmless, but can be annoying. You may need a new inlet valve. But first just try detaching and re-attaching the hoses to the valve. Sometimes that's enough to fix it.
2answers
My Braun 7570 has suddenly stopped working, but there is a high pitched whine when I switch it on.
This sounds like a battery problem. The likely remedy is to replace them. You will find batteries for your shaver at shaveroutlet.com
11helpful
5answers
debris caught iside pump assy is what it sounds like
10helpful
Feb 23, 2008 • Dishwashers
High pitch whine/sqeak
Suggestion: Try some anti-squeek on the belt, or some soap. Plug off the wall first.
Top Bosch Dishwashers Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
