Question about Xerox Office Equipment & Supplies
What about using 8500 ink for an 8560 printer?
Posted by miriam1964 on
Anonymous
  • 526 Answers
The inks are different types. If you have no choice, you can cut out the ink to make it fit in the ink tray, but you will first, lose ink because of that. I would only do it as an emergency.
you can get the ink sticks jammed in there because it won't go smoothly down the rails, also there is a guide rail that the inks trigger a sensor, if it does not trigger it, you will eventually get an ink out error.
Posted on Nov 22, 2010
5 Related Answers
Anonymous
  • 208 Answers
SOURCE: Phaser 8500 Ink
No. You will wind up with a bad ink loader.
Just had someone try it.
Posted on Dec 04, 2007
good-cents
  • 4 Answers
SOURCE: Phaser 8400/8500/8560 maintenance kit
No, it will not work because the chip (CRUM) is not compatable.
Posted on Jan 13, 2009
jmdprinter
  • 3 Answers
SOURCE: xerox 8560 how to remove ink blocks?
you have to take the ink loader out and turn it upsidde down and kind of work them out...or you could try to pull them out if you have some skinny tools like spring hooks..
Posted on Jan 13, 2010
Sheldon Dedek
  • 912 Answers
SOURCE: Does phaser 8560 and 8500 take same ink
The 8500 and the 8550 do use the same solid ink cartridges. Not sure about the 8560 since couldn't find information about it.
Posted on Jun 24, 2010
Testimonial: "Thank you for your help much appreciated "
SOURCE: Xerox 8500 excessive ink use
Hello Phaser 8500 owners,
I found a way to restrict the wasting ink problem of excessive cleaning cycles:
Just unplug the connector of the ink pump. One can find this pump behind the left plastic cover. Unplug the connector of the pump during the excessive cycles and put it back on again after.
To my experience the cleaning cycles come too soon or too often.
Good luck,
Tim
Posted on May 09, 2011
What is the error on phaser 8560 09,035.43:30363
At 30,363 pages the cyan ink has a miscount or stuck flag. It can be caused by using other than OEM inks. I would check the ink and make sure it is feeding down properly.
Oct 21, 2014 | Xerox Phaser 8500/DN Printer
Xerox phaser 8500 ink sticks wrong shape
If the ink shapes are wrong on an 8560, it probably means that it was in the managed print version of Xerox - Someone was paying for prints, not for ink and the ink technically belonged to Xerox. Normal ink should fit fine and you should get your money back from the person who sold the ink (you will see the word "metered" on the box.
Aug 24, 2013 | Xerox Phaser 8560DN Laser Printer
Xerox phaser 8500 error code 09, 038, 46:4597
Ink count sensor flags are stuck after melting 2.5 ink sticks. The following codes are recorded: 9,03x.41, where x= 5 for cyan, 6 for magenta, 7 for yellow, and 8 for black. (Your error indicates black ink loader failure)
Features on the bottom of genuine Xerox ink sticks actuate the Ink Out Sensor located at the forward end of each ink channel of the Ink Loader. The sensor indicates the passage of ink to provide a count of ink consumption.
Damaged or non-genuine ink sticks may not reliably actuate the sensors. This can lead to false Ink Out messages as well as Ink Stick count faults. Using 8400 model ink in a 8500/8550/8560 models will also cause 9,03x.4x ink stick count faults.
Ink Loader will need replaced and then diagnostics entered to run "Clear ISC Fault" test to clear the error.
IIf
Aug 11, 2013 | Xerox Phaser 8500/DN Printer
Genuine Xerox 8560 Ink Blocks don't fit
call servicedesk, maybe you got the cubes for europe/USA/Asia. They are a bit different
Jul 13, 2013 | Xerox Phaser 8500/DN Printer
During its warming up cycle, my Xerox Phaser 8560 stop before it can sent a text page and show ''printer error 09, 038, 46:1172'' on its display. Printer do not become operational at this...
Here's what the service manual has to say:
9,035.43 through 9,038 (8500/8550/8560 only): Ink count sensor flags are
count faults.
Jul 18, 2011 | Office Equipment & Supplies
Error message 09,038,46:20728 on xerox phaser 8560
That error states that the ink counter sensor flags are stuck. 9,038 means it is the black one. Make sure there is no blockage in the ink loader and that you are using Genuine Xerox ink sticks. If both of those are fine you need to replace the ink loader. The part # is 133K27711, iteminconline.com has it in stock and can ship same day. Good luck!
Feb 16, 2011 | Xerox Phaser 8500/DN Printer
09,035.43:46672 this is an error message i get on my xerox phaser 8560... can you tell me what it means?
If after following mariolands advice the problem continues, you will need to replace the ink loader, for the 8560 ,the part number is 133K27771. Here is a video that will show you how. The video also covers the 8400, 8500, and 8550. Though the part numbers are different the procedure is the same. ">
Jan 30, 2011 | Xerox Phaser 8560DN Laser Printer
Jun 24, 2010 | Xerox Phaser 8500/DN Printer
Error code 09,036.44:34979 What does this mean and what can I do to resolve it?
Oct 23, 2009 | Xerox Phaser 8500/DN Printer
Phaser 8560 error code
Most likely you are using generic ink or ink not made for that specific machine. The black ink is the one causing the problem. the printer will then need to be reset.
Apr 15, 2009 | Xerox Phaser 8500/DN Printer
59 people viewed this question
Top Xerox Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Muntejaya Ginting
Muntejaya Ginting
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
