The buttons next to the power button at the right of the display.
There is a microphone symbol next to the buttons....
1 = a and arrow down
2= b and arrow up
3= rotate screen button
4= fn button
ent = alt.
If you selected
http://uk.ts.fujitsu.com/rl/servicesupport/techsupport/lifebook/LIFEBOOK/E-Series/images/Screenshots/Image5.jpg
Example:
If you checked the boxes 1234 pres the buttons 123and4 at the same time. next press ent (ent is next to power button)....
when you press any button that make a beep sound... If the pass is wrong it will beep constantly for one minute..
other example: 1 - 2 - 14 - 4 in the first just 1 press 1 in the second 2 press 2 in the third 1 and 4 press 1 and 4 at the same time in the fourth 4 press 4 finally press the button ent.
So you're connecting with WiFi eh? I take it you've already disconnected and reconnected with no progress?
Next would be to shut it down, and reboot. Try it again.
Are you connecting through a router? You might be "connected" to the router/hub but it may not be actually connected to the internet. Can anything else you have or someone else connect to the internet through the same connection? If so then we know the connection is good, and it's the Lifebook.
Look for "NETWORK AND SHARING CENTER" and see what that looks like. It should show you a graphic of the connection and you may find it as I described above. You need to eliminate or identify your condition at this point.
i had the same problem, i had to install the updates on the "drivers and applications restore cd". however that didnt work. so i had to download the 1.030 driver from the fujitsu web site. this worked. but when i tried to calibrate the tablet i was not able to get it aligned.
there used to be 2 different programs for updating the tablet, but now i cannot find the other one.
