Question about Jabra Cruiser InCar Speakerphone Black
Cannot get my new Iphone 4 to pair with my Jabra cruiser bluetooth. I am in the setting and have the phone looking for the the Jabra but can't find it?
Posted by tedp278 on
Ed Nelson
  • 149 Answers
On your phone, make sure bluetooth is turned on (settings, general).
While your phone is in discovery mode, turn your bluetooth device on and put it in discovery mode (usually you have to hold the power button for 7-10 seconds).
Your phone will find the device, and you will be prompted to enter the devises PIN number (often 0-0-0-0). Your phone should pair with the device then.
Posted on Jan 05, 2011
My jabra bluetooth headset is paired and on. Now how do I get my iPhone 7 to use the headset vs the phone speaker?
  • 1.Touch Settings
  • 2.Touch Bluetooth
  • 3.Ensure Bluetooth is turned On
  • 4.Ensure the JABRA BIZ 2400 USB is turned ON
  • 5.Press and hold the O button until you get a solid blue LED
  • 6.Touch the JABRA BIZ 2400 USB in the list, If requested, enter the passkey 0000 (4 zeros)
  • 7.The JABRA BIZ 2400 USB is now paired
  • 8.The JABRA BIZ 2400 USB and the iPhone 7 are now ready to be used
Feb 04, 2018 | Jabra Radio Communications
How to pair the samsung galaxy s4 to the jabra cruiser
  • Touch Apps
  • 2.Scroll to and touch Settings
  • 3.Ensure Bluetooth is turned on
  • 4.Touch Bluetooth
  • 5.Slide the Power switch to turn the JABRA CRUISER on
  • 6.Press and hold the Multifunction button until you have a rapid flashing blue LED
  • 7.Touch the JABRA CRUISER in the list of devices
  • 8.The JABRA CRUISER is now paired
  • 9.The JABRA CRUISER and Galaxy S4 are now ready to be used
  • 10.Press the FM button in order to start streaming audio via the FM transmitter. The FM LED will turn red
Oct 01, 2014 | Jabra Cruiser InCar Speakerphone Black
How do I "pair" the Jabara Journey with a I Phone 5C?
most pairing when asked by the device requires a 00000 passcode
but you need to set the jabra and the iphone up for pairing
here is a link for jabra the iphone should see it when the jabra is set to set up mode..
http://www.jabra.com/support/Jabra-JOURNEY_100-47300000-15
Oct 11, 2013 | Jabra Cruiser InCar Speakerphone Black
I'm having difficulties pairing my iPhone 5 with my Jabra Cruiser. The unit appears to be in pairing mode when it turns on (flashing), but I never receive verbal confirmation from the unit. I'
the Jabra Cruiser is most likely not compatible with your iphone 5. Apple makes their products to connect only with their products most of the time. ive tried connecting my tracfone\'s bluetooth to my ipod touches bluetooth and cant pair them. Xbox 360 pulls the same issue too. so you probably will have to purchase a different car cruiser
Apr 18, 2013 | Jabra Cruiser InCar Speakerphone Black
Connect to iPhone 4
Hold the "Answer/End" button on your Jabra Bluetooth headset down until the LED light on the headset turns solid blue. The location of the button may vary based on which headset you have, but its appearance will be the same; it is the button that has an image of a telephone on it.
Click on the "Settings" icon from the main screen of your iPhone 4 .
Click on "General" in your iPhone's "Settings" menu.
Click on "Bluetooth" to access your iPhone's Bluetooth menu and then click the option to turn on your iPhone's Bluetooth connection. Once your iPhone's Bluetooth is turned on, it will search for available Bluetooth devices.
Select your Jabra headset by clicking on the icon that appears on your iPhone's screen.
Enter the passkey for your Jabra Bluetooth headset. The default passkey on Jabra headsets is "0000."
Click on "OK" on your iPhone 4 to complete the connection to your Jabra headset.
Tips & Warnings
The LED light on your headset must be solid blue to pair to your iPhone. A flashing light indicates your headset is not yet in pairing mode and your iPhone will not be able to connect to the headset.
Having your iPhone 4 Bluetooth turned on will drain your phone battery faster than normal.
Apr 13, 2011 | Jabra Bluetooth Headset - BT2070
Cannot pair my iphone 4 with jabra sps5050
The reason is you need a four digit code in order to pair your Bluetooth to your phone. Also, your phone has to be 'Able to be found', ie, set your Bluetooth settings on your phone, so that the phone is in 'Discoverable Mode' and ensure the Bluetooth setting itself is also turned on.
Once your phone is Bluetooth discoverable, try and pair the devices again. Your phone will find your headset and ask if you would like to pair the two devices. Obviously, select Yes/Pair and it will then require a 4 digit code for authentication. With Jabra the code is always "0000" (4 zero's). Once you enter the 4 zero's, the two units will then pair successfully.
Let me know if you require further assistance.
Feb 18, 2011 | Jabra SP5050 Bluetooth Headset
My wife lost her iphone and i cant get her new iphone to pair with her old jabra blue tooth
Hello Chris,
Did you try going into "discoverable" mode in the headset?
Please follow these steps and this should help you pair it with the iPhone.
1. Go to Settings > General > Bluetooth 4. Ensure Bluetooth is turned On 5. Ensure the headset is turned Off 6. Press and hold the Answer button until you have a solid blue LED 7. Touch the headset in the list (on iPhone) 8. The passkey is 0000 (4 zeros) 9. Enter the PIN 10. Tap Done
If that's not the problem, then let me know. I'll be glad to help you out.
Please rate this solution if it helps you.
Feb 18, 2011 | Jabra Cruiser InCar Speakerphone Black
Reset iphone need assistance please to start jabra again
but the speaker in pairing mode by pressing and holding the multifunction button until the blue led flashes.
on the iphone, go to settings, 'General' and then 'Bluetooth' and select to 'On'
the iphone will find the speaker and it will appear in the list. when it does, tap it.
tap 'Pair'
you are done.
Dec 17, 2010 | Jabra Cruiser InCar Speakerphone Black
I have tried everything in the manual to pair it with my iphone 3GS 4.1 but it's still not pairing. The iphone is looking and looking but doesn't find the device. Even turning the jabra stone of and then...
Dec 15, 2010 | Jabra Stone Bluetooth Headset
I purchased a new Iphone and my Jabra will not pair. I removed the Jabrsa connection from my old iphone and the Jabra still will not connect. How to reset Jabra and pair new phone?
To remove the list, press and hold the Answer/End button, Volume up button and FM button at the same time. A beep indicates the list was removed from the speakerphone memory. The next time you power on, the speakerphone will go into pairing mode as the first time you powered your new Jabra CRUISER on.
Thank You
Nov 12, 2010 | Jabra Cruiser InCar Speakerphone Black
Jabra Cruiser InCar Speakerphone Black Logo
1,973 people viewed this question
Top Jabra Cell Phones Experts
Anthony Ward
Anthony Ward
Tom Chichester
SANTHOSH
Are you a Jabra Cell Phone Expert? Answer questions, earn points and help others
