SOURCE: SimpleTech SimpleDrive Portable Hard Drive
No need to pay money to get back the data.
Open the link given below you can have all the information with images.
Just follow it.
http://lifehacker.com/software/disk-recovery/geek-to-live--rescue-files-with-a-boot-cd-192982.php
I hope this will resolve the issue.
Good Luck.
Live, Love, Laugh.
SOURCE: how do you use SimpleTech SimpleDrive S500U 500 GB Turbo USB 2.
http://www.simpletech.com/content/support-user-guides
That link is a page with all the user guides for simple drives. This should supply you with instructions. If you need any further help, let me know.
SOURCE: SimpleTech SimpleDrive Pininfarina 320GB Power up problem
It could be that it's internal power supply burnt out,
in which case the drive itself could still be fine.
Try opening up the external case, and removing the drive.
Once you do, plug it in to your computer directly using its SATA cables, and see if that works.
Hope I helped,
Tom
SOURCE: General questions regarding simpletech simpledrive.
You probably have to initialize and/or format the drive.
Right click my computer and click Manage (assuming windows xp)
Go to disk management
See if you see the drive listed somewhere there. Should show approximately 950gb disk drive
If so right click that drive listed and choose either format, or create partition.
If you create the parttiion, make sure to click quick format, otherwise it will take a long time.
Hope this helps
SOURCE: SimpleTech SimpleDrive 640 GB external USB harddrive wont turn on
Loose connection inside the Drive case. Remove drive and check internal wiring.
