Model #ED 271 APG Briel Multi Pro Series First, on the coffee side the light comes on, but does not make coffee. Second, On the expresso side I have cleaned the screen, but there isn't but a trickle of coffee that comes out. I have had this machine repaired twice before, and am fustrated with the problems we encounter. Please assist. Robert Parker 714.901.6221 Home (Call First) 310.245.1853 Cell
SOURCE: Briel Multi-Pro Coffee / Espresso Maker
You can contact the service center for detailed info:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700
fax 201-439-1701
[email protected]
www.electra-craft.com
SOURCE: help!!!!
You can get any Briel part that you need at the distribution/service center at:
Electra-Craft
41 Woodbine St
phone 201-439-1700
fax 201-439-1701
[email protected]
SOURCE: Briel Versatile Due Coffee Machine
You can get it at the Briel service/distribution center at:
Electra-Craft
41 Woodbine St
phone 201-439-1700
fax 201-439-1701
[email protected]
SOURCE: Spares for Briel Coffee Machine
You can obtain any part at:
Electra-Craft
41 Woodbine St
phone 201-439-1700
fax 201-439-1701
[email protected]
SOURCE: Briel ES 200 AP machine no water for coffee but yes for steam
This post is REALLY old, so you probably already fixed or discarded your machine. But for others with similar problem....
You may have a blocked top filter screen. If the machine is not cleaned regularly this screen can become so dirty and clogged that the water cannot get through.
Easy way to tell is run a shot without the portafilter basket in place. Water should flow out of the top screen. If you see it spurting out in small streams it needs to be cleaned.
On the ES200AP MPS machines you simply need to remove the screw in the middle of the screen, clean well, then replace.
