1) The eMachines T3626 uses an ESC MCP61SM-GM motherboard,
http://support.gateway.com/s//MOTHERBD/Shared/4006233R/4006233Rnv.shtmlClick on > Product Views
Now click on > P- Front Panel Connector
http://support.gateway.com/s/MOTHERBD/Shared/4006233R/4006233Rmvr18.shtmlDid you connect the cables, (Wires), from the Front Panel to the Front Panel Connector, correctly?
Looking at the Front Panel Connector, observe where it has > 2, at the bottom.
(Right above the small round object with the Orange dot in it)
This is the Bottom of the Front Panel Connector
The pins are in Two columns.
The column on the Right side is numbered > Even
The column on the Left side is numbered > Odd
Starting at the Bottom going Up on the Right side,
Pins 1, 3, 5, 7, and 9
Starting at the Bottom going Up on the Ledt side,
Pins 2, 4, 6, 8, and there is NO Pin 10.
A) Pins 1 and 3 are for the HarDDrive Activity LED light
B) Pins 5 and 7 are for the Reset switch. (IF one is used)
C) Pin 9 is for the 5+ power
D) Pins 2 and 4 are for the Power On LED light
E) Pins 6 and 8 are for the Power On switch
F) There is NO Pin 10
Let me know in a Comment.
