SOURCE: Alarm
the alarm is there to warn you that the freezers not up to set tempature.. The reason as I see what you wrote would be a stuck or burnt out auto defrost timer motor. or the units got a leak in the refrigerant line??? good luck
SOURCE: GIBSON DEEP FREEZE IS RUNNING BUT EVERYTHING IS THAWING OUT
Might try unplugging for a few hours and then plug it back in. There is a possibility that it slugged the compressor and there is a restriction in the line. Sometimes when the compressor fails to stop running in cold air the liquid gets back to the compressor. It can cause a bit of gunk to be picked up out of the oil and carried to the expansion line and plug up the line. Maybe turning it off will let the plug fall free and not replug the line. Worth a try anyway.....
i have a gibson up right in clean condition about 15 years old, the seal was broken on the door and the freezer began to thaw , i noticed it about 2 days later and lots of food was thawed but still cold, i cleaned the freezer and it has never been the same , it wont even freeze hot dogs . any help
SOURCE: why the deep freezer ice up inside top front
It freezes up because there's warm air going through the door or the gaskets are letting the outside air getting in.
SOURCE: Kenmore upright freezer alarm sounds constantly
replace the battery in the grill or the hi-voltage control under the unit in the back
