Whirlpool GBS277PDS Electric Single Oven Logo
Posted on Nov 22, 2010
AKZ 669 oven, flashing sign "door lock" and cannot stop. Once I was unplugged oven this problem stopped and oven works well. For ex. with grill function on highest (5) level, when grilling 1 kg chicken I must grill them for almost two hours to be done. How can I fix this. Thank you very much
5 Related Answers
A
Anonymous
  • Posted on Jan 30, 2008
SOURCE: Whirlpool Double over
Whirlpool RBD245PDB6 went dead and locked up during self cleaning. It was the third or fourth time in 8 years we used self cleaning. The TCO in the back was open, replaced it but still inoperative. I found a thermal limit fuse in line on the black wire leading to the printed circuit board. It too was open, after replacing it the oven works fine. Check both fuses.
A
Anonymous
  • Posted on Feb 19, 2008
SOURCE: Faulty oven
you need to either set the time, or just press the centre button to activate the cooker.
Anonymous
  • 8197 Answers
  • Posted on Jan 07, 2009
SOURCE: Whirlpool accubake self clean oven. Error code(s) E2 - F3?
You can get all the codes here.
F3 E2 9 Bake range over temperature At room temperature, sensor resistance should be 1K to 1.1K. If not, replace the sensor. If the sensor checks okay, replace the control.
http://www.repairclinic.com/0078.asp#Westinghouse
Good Luck and Please Rate FixYa!
Paul Davies
  • 157 Answers
  • Posted on Mar 09, 2010
SOURCE: i have a whirlpool akz451 oven.the oven does not
element around fan
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on Oct 30, 2010
SOURCE: My AKZ451 oven has stopped heating up. The grill,
You need to replace the oven element, located at the rear of the oven compartment, behind a removeable cover.
Testimonial: "Thank you"
Gibson oven door is locked after attempting to do self-cleaning.
Unplug it. Plug it back in, then press n hold start. Make sure lock handle is all the way locked. You may have to push on the door at same time while locking n unlocking. If that doesn't work, shoot it. Ha
Sep 24, 2012 • Ovens
Self clean is locked but door still open
oven won't heat, "door locked" always flashing if I push"off/cancel there is a crackeling noise and "F9" fashes for a while then stops, Display flashes "door locked" but door will open but will not heat and now always flashes "door locked"
Lock sign won't go away
the switch for the lock has an interlock to keep it from working when the door is open this may be shot
Aug 23, 2009 • Ovens
Door hinge of oven detached on one side
two hidden levers on end of hinges. When raised, door able to be re-inserted or completely detached.
very simple once i discovered levers on the hinges.
Dec 19, 2008 • Ovens
1helpful
Oven door locked - jenn air
My Jenn-Air double oven locked after a clean cycle. My model (JJW8630) has a series of slots cut in the top of the door. Take a piece of stiff wire, coat hanger, and bend a right angle about 1/2 inch at the end, feed the wire into the 3rd or 4th slot from the center on the right hand side. Turn the wire so that the bent piece is on the top and push the wire so it engages the lever which latches the door shut, it is spring loaded and moves easily.
Once the door was opened, I removed the temperature sensor, held by 2 screws, from the top of the oven and eased the wire out to get to the connector. The faulty sensor was reading 4.2 k, at room temperature it should be just over 1k, while waiting for a new sensor to arrive I stuck in a 1k resistor, ex Radio Shack, so the fan stops running and the door latch can be retracted by closing the oven door, or press the switch on the top right of the door opening.
My replacement part was ordered on line for less than 1/2 the official quoted price.
Hope this helps.
2helpful
3answers
Kenmore 790 Oven Locking mechanism problem
I had the same problem. Open the oven door. Press and hold the light switch. You will hear the door lock move back into the correct position. Hope this fixes your problem. This has happened to me twice and holding the light switch always works.
Ge oven problem
door lock is not work check wires motor and switchs.. you may have to replace the door lock
2answers
F2 error
what is solution
Dec 08, 2007 • Ovens
4helpful
4answers
Amana oven
Error F-9 means:Door lock safety circuit on ERC sensed Replace the door latch assembly
To solve this...Just press and hold the door latch to unlock position and then press cancel for a few seconds. The latch will return to its original position
This will probably fix it..but if doesnt work try this
Try unplugging the oven from the electrical power. May release the lock, which is held in place by a tiny micro switch. If not and while the electric is still off or the oven is unplugged, use a bright light flashlight to look through the slot where the lock is in the oven, not in the door.
You may be able to use a thin blade screwdriver to move the lock to the release position. Check the angle of the lever. A slightly bent lever handle also can cause this type of condition.
If all else fails, remove the access panel on the front of the oven to access the locking device and release it. May have to disconnect the wires to the lock which will allow door to function but not during any self cleaning modes.
Oct 17, 2007 • Ovens
2answers
Ge oven problem
Look for a microswitch connected to the lock mechanism at the back of the stove. The switch is probably broken.
Top Whirlpool Ovens Experts
ZJ Limited
ZJ Limited
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
