Question about Sony Video Game Consoles & Games
Hello! my ps2 900004 playing just one ps2 game disc,and some dvd movies. what i do
Posted by abidbutt300 on
Benjamin Jr Singson
    Genius:
  • 1,570 Answers
Mabe the CD/DVD has a lot of scratches
or those dvd games is not supported your regional settings
Posted on Nov 23, 2010
Can not play movies
Do you mean you're attempting to watch a DVD or Blu-ray disc or a movie through software like Netflix or Hulu Plus? The Wii will only play Wii (and Gamecube if it is an older system) game discs.
Dec 30, 2013 | Nintendo Wii Console
Tip
Try this to play DVD movies on your PS2 if it wont play DVD movies.
If your PS2 works fine with Games and just wont play any DVD movies at all.Then you should try this trick to play movies on your PS2:
  1. Turn on your PS2 without inserting any disc.
  2. Menu screen will appear like:894e4e5.jpg
  3. Press the ps_b_triangle.gif (triangle) Button to enter Version Information Menu that looks like3aef030.jpg
  4. Highlight the Play Station Driver as above and again press ps_b_triangle.gif (triangle).
  6. Highlight the Disc Speed as above and press ps_b_x.gif button,to enter Disc Speed Menu
  7. And set it from Standard to "Fast".
  8. After you set Disc Speed to Fast, Press and Hold Reset Button to turn off your console.
  9. Then again Press and Hold Reset Button till the Blue Light turns on.
  10. Remove the Reset Button and Press it again.
Be patient and wait till the movie plays itself.If your lens is good then it will play DVD in first go else try again till it PLAY your DVD movie.
Thank you!
on Nov 29, 2009 | Sony PlayStation 2 (PS2) Console
My ps2 won't play movies
Its probably the DVD drive even if you can still play games, be happy it still does that and ask for a cheap dvd or bluray play for xmas.
besides playing movies on your ps2 will wear out the disc dive further (even more than games would) sorry bud, its not worth it.
Dec 15, 2012 | Video Game Consoles & Games
When i put an Xbox 360 game in it tries to play it as a DVD movie. please help!!!
When you try to play a DVD movie or an Xbox 360 game disc on your Xbox 360 console, you may receive an error message. This article presents step-by-step guidance to help you determine whether your disc is playable.
SYMPTOMS When you try to play a disc, you may receive the following error message: Can’t read this DVD.
CAUSE The DVD or game disc may be dirty or damaged. Because the console cannot read the disc well, it may even mistake a game disc for a DVD and report this error. If this problem occurs with multiple discs, even clean and undamaged discs, there may be a problem with your Xbox 360 console.
Note If you receive a different error message, such as one of the following messages, the problem is a different problem:
Error message 1 Can't play DVD. Wrong region code. Error message 2 Can’t play DVD. Family settings restrict playback of this DVD. If you receive one of these error messages, see the corresponding Knowledge Base article: 907620 While attempting to play a standard DVD movie using your Xbox 360 console, you receive the error message: "Can't play DVD. Wrong region code" 908645 While attempting to play a DVD movie using your Xbox 360 console, you receive the error message: "Can’t play DVD. Family settings restrict playback of this DVD"
THINGS TO TRY Here are some things that you can do to try to fix the problem or to determine what caused it.
Determine whether the disc is dirty or damaged Discs that are smudged, scratched, or otherwise damaged cannot be read by the Xbox 360 console. You will want to examine the disc to see whether it has smudges, scratches, or other damage. To do this, follow these steps: 1. Examine the disc for dirt or damage: a. Pick up the disc by its edges. Do not touch the top or bottom surface. b. Examine the shiny side of the disc to make sure that the disc is clean and has no damage.
NoteScratches that follow the curve of the disc are very damaging and prevent a disc from being read. If your disc has even one of these kinds of scratches, the disc is damaged, and you will no longer be able to play it. If this is the case, see step 4. 2. If the disc is dirty, clean the disc by hand: • Use a soft, clean, dry, chemical-free cloth to clean the disc. • Lightly wipe from the center of the disc outward. 3. After you clean the disc, try to load it in the Xbox 360 console. If the disc still will not load or you receive the same error message, the disc is damaged, and you will no longer be able to play it. If this is the case, see step 4. 4. If the disc is damaged, do one of the following: • Because DVD discs are not game discs and the disc was damaged because of misuse of some type, such as not storing the disc in its case, the only thing that you can do is buy a new one. • If you feel that the disc was damaged by the Xbox 360 console in some way, please contact Xbox Customer Support. To do this, please visit the following Microsoft Web site: http://www.xbox.com/support/contact
Feb 18, 2010 | Microsoft Xbox 360 Console
PS3 wont play blue ray or PS3 game discs
Please check the region code on the BD or DVD. It should match the region code set in the system. Otherwise the disc will not play
Nov 28, 2009 | Sony Playstation 3 (PS3) Console
Solutions to incorrect disk error c105 & c104
Hello gjbrokke,
First make sure the disc is compatible with the dvd player (CD-R+ , or CD-R - )
Second make sure the region code of the dvd you burned is compatible with the dvd region settings on your dvd player.
One of those two are preventing the disc from playing in your sansui player.
May 19, 2009 | Sansui VRDVD4005 DVD Player/VCR
How can i use ps2 as dvd player?
Just load the disc the same as a game and it will play dvd movies. Use the controller to press play/start
Jan 29, 2009 | Sony PlayStation 2 (PS2) Console
Ps3 was playing movies i had burned to disk now it wont
The best way to play burned movies is to copy them onto a memory stick or external hard drive then copy them onto the ps3 i use this method and find the movies play in much higher quality than dvd-r or+r or whatever discs you use
Jan 25, 2009 | Sony Playstation 3 (PS3) Console
PS2
What it is, is from it playing on any burnt movies so now it won't play factory burnt discs only home-made burnt discs, try the movie on a home-made burnt disc. If nothing you can get a DVD player for like 20 bucks at wal-mart.
Apr 04, 2008 | Sony PlayStation 2 (PS2) Console
Video Game Consoles & Games Logo
Top Sony Video Game Consoles & Games Experts
Daniel Dollive
Daniel Dollive
Steven Wander
Steven Wander
Raj Patel
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
