1. Connect to your router Globe B315s-936/938 (via Wi-Fi using the default credentials printed at the back of modem or connect directly thru LAN cable).
2. Open your web browser, and enter 192.168.254.254 in the URL address bar to open the Globe Broadband web interface/dashboard.
3. Click Login on the upper right of website interface. Type the Globe default admin username and password. Username: user and Password: @l03e1t3
4. Open WiFi settings. For 938 modem, go to Wi-Fi Settings For 936 modem, go to Settings > WLAN > WLAN Basic Settings Set the settings to: SSID: Your Desired WiFi Name Security mode: WPA/WPA2-PSK WLAN Key/WPA Pre-shared key : "Your Desired WiFi Password" SSID broadcast: optional settings if you want to set your wifi as public or hidden.
5. Click Apply and you are done.
"The default log-in credentials for de Web Config Interface are "admin" for the username and the password you create the first time around. As with all routers, you can always restore it to default factory settings via the recessed reset button on its back."
Please reset your router and enter gain using the default username and password. The default username and password for Netgear routers are admin and 1234 respectively.
1. Open your web browser and type in your router's IP address. The default IP address for Netgear routers is http://192.168.2.1. 2. Enter your username and password once prompted by your web browser. The default username and password for Netgear routers are admin and 1234 respectively. 3. Select "Set Password" from the left hand navigation menu on the router's manager menu. 4. Type in the old password, which should be 1234 if it is set to default and then type your new password twice. 5. Click "Apply" and the new password will take effect immediately.
log into your router via your default gateway which by default will be 192.168.1.1 Type 192.168.1.1 into your web browser when it prompts for a username by default it will be username: "admin" password: either blank or "admin" also
In a web browser, enter the router's IP address - either http://192.168.0.1 or http://192.168.1.1 by default.
When prompted for a Username and Password, enter the default username and password (admin; password)
unless you have already changed it. NETGEAR recommends changing the
default password to increase the security of your network.
Select Wireless Settings from the Setup menu in the left-hand navigation bar.
Select Configuration|Security from the Access Point menu tree.
Select ModifySystem Password.
Configure the AP password settings as required:
System Password
Select any alphanumeric,
case-sensitive entry of up to 13 characters. The characters selected
are displayed as asterisks. Changing this passowrd changes the
Read/Write Community password found in the SNMP Configuration screen.
The default password is Intel.
Confirm System Password
Select the same alphanumeric, case-sensitive entry of up to 13 characters as System Password. The characters selected are displayed as asterisks.
