NexxTech DP3222 DVD Player Logo
Question about NexxTech DP3222 DVD Player
I have a Nexxtech MINI DVD player - model No.1617011. The power switch will not turn on the player, and therefore the eject tray will not open. [email protected]
Posted by ken_putman on
5 Related Answers
Anonymous
  • 3 Answers
SOURCE: Disc Tray Will Not Eject
Just next to the eject button on the actual recorder there should be a tiny pinhole.  If you use a small paperclip and insert it, then push, you should be able to manually eject the DVD.  Hope this helps!
Posted on Oct 16, 2007
Anonymous
  • 3 Answers
SOURCE: Frayed wire???
See my other posting. I doubt it's your power cord at all. These units are notorious for this. Do a 'google' search on them and see what I mean. I can only reccomend that you invest in some research before buying another one. Price is NOT everything! It ain't a bargin if it's worthless! (Or: Paying anything, however little, is TOO much for something worth nothing) I will canabolize mine for the screen. I paid $20.00 for it at Goodwill. I know how to do this, but I realize most folks don't, or do not have the time, nor inclination to do so. I'm disabled, so time I have, money I don't.
Junkman
[email protected]
Posted on Mar 27, 2008
Anonymous
  • 417 Answers
SOURCE: nexxtech dp3222 dvd player
DISC IS STUCK U NEED TO OPEN DVD PLAYER REMOVE MANUALLY ITS REALLY EASY TO DO JUST TAKE THE SCREWS OUT TAKE LID OF REMOVE DISC THEN PUT LIT BACK ON PROBLEM SOLVED
Posted on Jul 02, 2008
Anonymous
SOURCE: DVD will no eject
This is not helpful. The power is on and display is on, but no response.
Posted on Sep 08, 2008
Anonymous
  • 1961 Answers
SOURCE: can not eject tray to load DVD disc
the mechanism of your dvd are stucked up lubricate the moving parts and gears by using a small amoun of lubricating oil.to do it manually eject the loader by turning the gears by your hand..
Posted on May 17, 2010
WILL NOT EJECT DISC
What is the model number of your DVD player? You may try power resetting the unit and check if it helps. To power reset, turn OFF the DVD player and unplug the power cord from the electrical outlet for 30 seconds. Plug the power cord back into the electrical outlet and turn the player ON. Attempt to open the disc tray.
Depending on the model number of your DVD player, simultaneously press the POWER + STOP + EJECT buttons. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.
NOTE: This step may not apply to all models as DISC1 is not available on all DVD players.
If this does not work and if the DVD player has DISPLAY and PREV buttons, press and hold the DISPLAY+PREV buttons for two seconds to unlock the drawer.
FOR SONY PLAYER's
This issue may occur if the disc is damaged or if the disc was not inserted properly into the Blu-ray Disc® player. Follow the steps below to open the disc tray and eject the disc.
  1. Turn off the Blu-ray Disc player.
  2. Disconnect the power cord (mains lead) or AC adapter.
  3. Allow the disc player to remain without power for 30 seconds.
  4. While pressing the OPEN/CLOSE button located on the front of the disc player, reconnect the power cord.
    IMPORTANT: For some Blu-ray Disc Home Theater models it is necessary to press and hold the OPEN/CLOSE andPLAY buttons simultaneously, then reconnect the power cord.
    NOTE: This step may require the assistance of a second person.
  5. After reconnecting the power cord, when the tray opens, release the OPEN/CLOSE button.
  6. Remove the disc.
  7. If necessary, disconnect and then reconnect the power cord to recover the player.
tip
How to fix DVD (not eject)
Please read my tips on how to fix the DVD players (not eject).
This problem is common on all DVD players such as VCD players,DVD/VCR combo,or even DVD ROM..
This simple tips is very easy to perform even you are non-pro in electronics.
This are the steps on how to do a D.I.Y troubleshooting:
  1. Remove the cover of your DVD player.
  2. Look at the DVD or CD tray assembly.
  3. Remove the whole CD tray assembly by loosening all screws at the left and right corner of the CD tray assembly and also you need to remove the front panel of the ejecting tray to get the whole CD tray assembly away from the DVD player for further repair and check-up.
  4. After that,look at the bottom of the DVD or CD tray and try to find out where's the motor that controls the ejecting tray.It is usually have a rubber O-ring or mini rubber belt that control the gear of ejecting tray
  5. Next,when you found the ejecting motor.Try to look at the rubber O-ring or mini rubber belt condition,if it is cut,loosen or disconnected from the motor.
  6. If the rubber belt is in good condition,check the ejecting motor.There are 2 ways of testing the motor,first the resistance checking-you should have a ohmmeter or multimeter (resistance or ohm range) point your (+/-) test prove to the terminal of the motor to measure the resistance.Secondly the actual testing-this procedure you need a battery 3vdc,connect the negative(-) terminal of the battery on the black wire of the motor and the positive(+) is connect to the red wire.If the motor is not spin-up replace it with the same type,rating,voltage and value.
  7. If you already done this procedure and the problem is still there after you replace the defective parts,if any.The problem could be the motor ejecting driver that found on the main board.This is not for D.I.Y because of the parts inside main board is very sensitive and hard to replace.If the trouble is on the main board you have to replace the whole main board or buy a new player.
Thank you for reading my tips.I hope to help you!!
on Jun 08, 2011 • Televison & Video
If press eject button,it's showing LOCKED.what can i do?
2answers
My sony dvp sr200p cannot eject the disk inside. i tried all the 4-digit code but i failed.
From www.sony.com
Unable to eject a disc.Solution
Follow the steps below to troubleshoot this issue.
IMPORTANT: If model-specific information is required to complete any of the steps in this solution, refer to the operating instructions supplied with the product. Manuals are available online through the Manuals/Specs/Warranty link on this page.
  1. Ensure the child lock feature is disabled.
  2. Attempt to open the disc tray.
  3. If the issue is not resolved, turn off the DVD player.
  4. Unplug the power cord from the electrical outlet for 30 seconds.
  5. Plug the power cord back into the electrical outlet.
  6. Attempt to open the disc tray.
  7. If the disc tray still does not open, simultaneously press the POWER + STOP + EJECT buttons.
  8. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.
    NOTE: This step may not apply to all models.DISC1 is not available on all DVD players.
Dvd player will not eject or play dvd. It just keeps spinning and says "reading." I've tried unplugging for 2 minutes, pushing close/open and stop at the same time(hold for at least 3 seconds)....
Plug the power cord back into the electrical outlet and turn the player ON. Attempt to open the disc tray. Depending on the model number of your DVD player, simultaneously press the POWER + STOP + EJECT buttons. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.6 Jan 2013
Solved: DVD is LOCKED will not eject. please help. Manual ... - the ...
https://community.sony.com/t5/Home-Theater.../DVD-is...will-not-eject.../td.../55919.
or try this link. Dvd player will not eject or play dvd Google Search
2answers
The dvd player tray does not open
# Ensure that any locking feature on the DVD player is disabled.
# Attempt to open the disc tray.
# If the issue is not resolved, turn off the DVD player.
# Unplug the power cord from the electrical outlet for 10 minutes.
# Plug the power cord back into a functional wall outlet.
# If the disc tray still does not open, simultaneously press the POWER + STOP + EJECT buttons.
good luck!!!!!!!!!!!
2helpful
2answers
Dvd won't play or eject
If you want to get the dvd out
you can try this:
First turn of you dvd player at the mains, Then power it up, But the moment it powers up press the eject button a few times so it doesn't start to load. If it doesn't work the first time try it one more time since you may not get the hang of it at first.
then you dvd should eject.
With dvd players like this, corrupt, copied or really scratched dvds may make your dvd player do this.
Regards
What dvd players do the mini dvd-rw discs play on?
Hello sir/ma'am good day, all dvd players has this small circle on the center of the tray, where you play the mini dvd disk. eject your dvd tray to see. hope this helps. thanks
7answers
CD is jammed in drawer of Philips MC-70 Mini Shelf System. Cannot open or play. How can I open drawer and extract CD?
look at the drawer is there a small hole on it? if so use a paper clip on that hole to eject the tray.
try unpluging it for few minutes and try again.
1helpful
I have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray...
same equql problem....?????
Can you help?
i have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray opens and the power button stays green. As soon as you close the tray the power agin goes to red. i have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray opens and the power button stays green. As soon as you close the tray the power agin goes to red. Can you help? thanks thanks
Top NexxTech Televison & Video Experts
ADMIN Andrew
ADMIN Andrew
Are you a NexxTech Televison and Video Expert? Answer questions, earn points and help others
