The anti theft light will flash fast on the dash if it's activated. You simply lock & unlock the doors to disarm it.
Check your inertia switch to see if it is activated. Press the rest button. Se owner manual to rest.
The control functions are contained in the instrument cluster. This module carries out all of the PATS functions such as receiving the identification code from the encoded ignition key and controlling engine enable. The instrument cluster initiates the key interrogation sequence when the vehicle ignition switch is turned to RUN or START.
The PATS uses the PCM to enable or disable the engine. The instrument cluster communicates with the PCM over the SCP network in order to enable engine operation. The instrument cluster and the PCM use sophisticated messages in order to prevent a theft. The instrument cluster and the PCM share security data (when first installed together) that makes them a matched pair. After this security data sharing, these modules will not function in other vehicles. The shared PCM ID is remembered even if the battery is disconnected. The instrument cluster also stores the vehicle's key identification code even if the battery is disconnected. There are special diagnostic procedures outlined in this workshop manual that may be carried out if either a new instrument cluster or PCM needs to be installed.
All elements of PATS must be functional before the engine is allowed to start. If any of the components are not working correctly, the vehicle will not start.
PATS uses a visual theft indicator. This indicator will prove out for three seconds when the ignition switch is turned to RUN or START under normal operation. If there is a PATS problem, this indicator will either flash rapidly or glow steadily (for more than three seconds) when the ignition switch is turned to RUN or START. PATS also "blips" the theft indicator every two seconds at ignition OFF to act as a visual theft deterrent.
The PATS is not compatible with aftermarket remote start systems, which allow the vehicle to be started from outside the vehicle. These systems may reduce the vehicle security level, and also may cause no-start issues. Remote start systems must be removed before investigation of PATS-related no-start issues.
Visual Inspection Chart
Mechanical
Electrical
- Ignition lock cylinder
- Encoded ignition key (PATS key)
- Use of non-encoded ignition key (key without the molded plastic head, non-PATS key)
- Use of a non-programmed encoded ignition key
- Central junction box (CJB) Fuses:
- Fuse 2 (5A)
- Fuse 6 (5A)
- Fuse 30 (30A)
- PATS transceiver
- Connectors
- Ignition switch
