From your description I must assume that the motor and fan are turning. If this is the case then you either have an extremely bad air leak between the air pump & nozzle, a restricted fuel line or vacuum leak, or the rotor in the pump itself is broken and needs to be replaced.
Check the pump pressure. If 0psi then the rotor is broken.
If there is "some" pressure, then look elsewhere.
