Question about Dell PowerEdge 1600SC Server
PROBLEMA EN SERVIDOR DELL 1600SC EL SERVIDOR TIENE 2 GB. DE RAM. LA BIOS RECONOCE LOS 2 GB, PERO AL ARRANCAR EL SERVIDOR DA ERROR 256 M O AL INSTALAR ALGÚN PROGRAMA COMO EL NOVELL, DICE QUE LA MEMORIA ES DE 256 Y HACE FALTA COMO MÍNIMO 512M.
Posted by romel219 on
3 Related Answers
nblady
NIK
  • 206 Answers
SOURCE: Quitar Password de Bios de Pc Dell Optiplex GX100,
Hope you can read this. if not, GOOGLE...TRANSLATE.
Removing the PSWD jumper is the correct method of clearing the BIOS password. Removing the battery resets the CMOS.
Remove the power from your computer. Remove the battery. Remove the PSWD jumper. Wait!!!!
Keep power off the computer for at least 30 minutes, overnight is better.
Replace the battery. Plug the computer in. Do Not Reconnect the PSWD jumper.
Now reinstall your operating system and drivers. When finished, restart your system. If everything works and you want to redo the BIOS password, shut the computer down. Unplug the power. Remove the battery. WAIT.
Replace the PSWD jumper. Replace the battery. Plug in the power. Restart the computer, hitting "F2" as it starts....to open the BIOS setup page. Reset your password here. Esc to continue, Yes to save.
Good luck
Posted on Feb 24, 2010
Mikenet2620
Miguel Espinoza
  • 106 Answers
SOURCE: No puedo instalar Small Business
Si el sistema operativo no reconoce tus disco, y ya has creado un arreglo nivel 1 o 5 y en la bios si puedes ver los dicos, el problema es posiblemente que necesites cargar los drivers de la controladora. Si puedes ver el modelo de la controladora (visible en el post) dirigete a la pagina de hp.com/support escoje el pais USA para que tengas acceso a todos los drivers, descargate el ultimo driver de tu controladora y cuando este instalando windows presiona f6 para cargar los drivers
Posted on Aug 30, 2010
Jimmy
  • 539 Answers
SOURCE: cuando se conecta el pc a la toma de corriente, se prende directamente la pc, no da video ni reconoce teclado ni mouse
http://www.manualowl.com
Posted on Apr 13, 2012
No puedo instalar Small Business Server 2000 en mi servidor HP Proliant DL360 G3, el software no reconoce los discos duros del servidor. Que tengo que hacer para que me reconosca los discos duros?
Aug 29, 2010 | HP Compaq ProLiant DL360 G3 Server
Si desconecto el HD y la unidad de DVD puedo entrar al BIOS pero al conecetarlos no aparece nada en pantalla, el disco duro y el DVD tienen los jumpers correctamente colocados, el cable IDE también...
Resultó ser que estaba dañada la memoria RAM, posteriormente intenté reinstalar el SO Win XP y me marcaba error de lectura, asi que probé con otro disco duro y logré instalarlo sin problemas, señal de que el disco se dañó tambien, antes de sustituirlo probé restaurar el SO con un disco de instalación de Win XP en la opción de reparar y lo intenté con los comandos FIXMBR y FIXBOOT pero no resolvió nada, por tal motivo decidí sustituir el disco duro, ya instalé software y drivers y todo funciona a la perfección..
Espero esto le sea útil a otros usuarios con problemas similares..
SaLu2
Omar Chimés
Sep 29, 2009 | Biostar K8M800 Micro AM2 Motherboard
Gigabyte GA-K8N Pro-SLI won't boot and no beep codes
hi kathy,
there are a few things you can try, reseting the cmos, with the jumper usually located near the battery. if you cant find that, try removing the battery for 30 mins and then popping it back in. if no luck from there, you could try another cpu, if that dont work then it may just be the mobo! good luck!
hope it helps!
Feb 11, 2009 | Gigabyte GA-K8N Pro-SLI Motherboard
Problemas con el cdroom y con el abanico
Hola. Soy Alex y estoy aqui para intentar a ayudarte con vuestro problema informatico
Me parece que los drivers (los controladores) de los CD rom ya no estan en tu PC se no parecen los iconos en MIPC. Que lo puedes hacer, si tienes XP es, ejecutar windows XP desde el cd cuando arrancar el ordenador y reparar la instalación de windows.
Espero que este es vuestro solucion
Un saludo!
Oct 12, 2008 | Computers & Internet
Porque mi placa se recalienta tanto donde se encuentra el procesador y la tarjeta de video
Hola te recomiendo un sistema de este tipo, ami me pasaba y con esto se soluciono ese problema http://www.bit-tech.net/hardware/cooling/2012/09/26/thermaltake-water-2-0-performer-pro-reviews/1 9ab6aa7c-9dc3-4642-ab5a-d10391656423.jpg
Oct 01, 2008 | Intel D865GBF Motherboard
Disco duro serial ata
Hola VooDooNOFX
Gracias por la ayuda
No estoy configurando los dos discos duros apartes ni haciendo raid a los dos juntos.
El D.D. de 80 gb IDE ya esta parcicionado y formateado (40 c/u, FAT32), tiene windows xp sp3. Uso teclado PS2.
En el D.D. 250 gb serial ata quiero particionarlo en cuatro partes e instalar windows vista, las otras tres particiones para datos.
Voy a hacer esto: Desconecto el D.D. 80 gb IDE y dejo solo instalado el D.D. serial ata de 250 gb para partionarlo y formatearlo con windows vista; primero sin desactivar la función de raid en la bios y luego desactivandola; que opina.
Sep 16, 2008 | MSI Microstar KT6 Delta (MS-6590)...
Dell PowerEdge 1600SC Server Logo
129 people viewed this question
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
