Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Check the CCFL lamps too, for low light emission, if the backlight of the TV is of CCFL type.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
SOURCE: Black Bar on screen
You can try to check the connector on the address board on that area, but I'm 99% sure the plasma panel is defective.
SOURCE: Samsung plasma tv hp-r4262
The x drive board is bad in the area you see as black. OR the cable came loose.
SOURCE: Lines on tv screen
Both sound like bad LCD panels. The following must be answered to confirm this:
Do the lines appear on all inputs/all signal sources?
Can they be seen in the OSD/menu?
If yes to both questions, it is likely that the LCD panel is bad
SOURCE: yellow tint on screen, little bright spots on the dark blue.
http://repairs.sunnyoasis.com/sonylcdtv/ this is a link on what to do i had same problem picture is like brand new now good luck this takes about 3 to 4 hrs
SOURCE: Vertical black bar down the middle of hitachi plasma tv
The tv is shot. This occurs when pixels on the top row of the screen break, which blocks current from moving through the rest of the pixels in that column. But don't worry this problem is common and is covered in your tv's warranty.
