Question about Nokia N72 Cellular Phone
Nokia N72. The camera is not working, every time I try using it, I get the message, camera on standby, open lens cover. Please help.
Posted by agasta2002 on
Anonymous
    New Friend:
You can chang your phone body.
because your phone back body is loosed so the booten can't touch.
chang body and use..........
Posted on Nov 22, 2010
Camera is not opening on opening the camera cover
TRY to open lens after switcing off and on it.or try after formatting..
Nov 13, 2010 | Nokia N72 Cellular Phone
I have nokia N72, camera is not working, after opening lens cover camera does not start, when i start camera going through imaging>camera, it shows the message "camera on standby, open lens cover" need...
@ above
dude im also facing da same problem( with N72)...hv u got any solution..coz i can see that ur post is almost a month old...so if u hv any solution then pls temme..
thanks..!!!
Sep 29, 2010 | Nokia N72 Cellular Phone
How to copy message from memory card to phone memory in nokia n72
open the folder, mark the messages, set destionation as phone memory, then copy them
Jan 06, 2010 | Nokia N72 Cellular Phone
Camera on standby open lens cover
take off the lens cover?, the cover blocking the actual camera lense, this is preventing the startup of the camera or your getting a black screen window right, or slide the cover that over the lense across
Jun 23, 2009 | Nokia N72 Cellular Phone
Camera automatic off
This is actually hardware problem.
When u open the lens cover behind,there is a small button which is pressed.The camera works until the button is pressed and goes off when released.you just tightly press your lens cover.or try consulting at service centres..
Apr 25, 2009 | Nokia N72 Cellular Phone
Camera error in nokia n72
i think the updation of the hard ware is required,,,. if ur version id starts from 2...... . u need to update, u can see ur version id by typing, *#0000# . u can either update it ur self by using ur pc suite ( use only data cable and nt the bluetooth ). or u can consult the local nokia agency
Apr 06, 2009 | Nokia N72 Cellular Phone
N72 Camera Error
my camera is also showing same issue...what you did to solve this?
Jun 04, 2008 | Nokia N72 Cellular Phone
How to format n72 cellphone not memory card only cellphone
this is a simple one that so many people ask ,there is no risk to do just do as i say
if u want to format memory card first format it,then
to format phone,,,,,,,
first remove memory card,then switch off the phone for 2 min and then switch on by pressing n holding the keys ASTERIK(*),3,CALLKEY(GREEN KEY).THATS ALL PHONE COMES TO ORIGIN.
NOTE:THREE KEYS SHOULD BE PRESS N HOLD WHILE SITCHING ON.
AFTER GETTING SOLVED U JUST VOTE ME / MSG ME.OK GD BYE...
Feb 18, 2008 | Nokia N72 Cellular Phone
"Cover Is Not Open" And The "Lens Cover" Is Open...
the lens cover switch of your camera have a poor contact that why that message is appearing...you have no choice but to disassemble the camera for repairing or cleaning that switch....i suggest you have to go the service center now and don't try open your camera if you are not a technician cause you may damage the flexwire of the lcd monitor if you not properly remove the cover...
Aug 30, 2007 | Sony Handycam DCR-HC21 Mini DV Digital...
Nokia N72 Cellular Phone Logo
116 people viewed this question
Top Nokia Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Zaid Anarwala
Zaid Anarwala
SANTHOSH
