Question about Rival VS230 Seal A Meal Vacuum Food Sealer
Just bought the seal a meal vs230 plugged it in and nothing happens. What is the problem?
Posted by mark_demelo on
Anonymous
    New Friend:
I thought I had the same problem. Kept reading the instruction manual to try to figure out what I was doing wrong or thought a fuse was blown or something (there wasn't even a light to show that it was getting power). It did end up working though when I pressed on the ribs on the lid with some force and held it for a second or two. It didn't work when I pressed down on the lid on the sides - only when I pressed directly on the ribs. It really surprised me when it lit up, but there you have it.
Posted on Dec 12, 2010
Where can i get a new heat tape for my seal a meal
Crazy,, I've only used it three times and the heat seal already went out,,, will never buy this product again
Apr 29, 2014 | Rival VS230 Seal A Meal Vacuum Food Sealer
Nedd the new tape for a seal a meal machine, rival
dated: Wednesday, November 20th, 2013
Call:
Rival Customer Service at 1-800-557-4825
Nov 13, 2013 | Rival VS230 Seal A Meal Vacuum Food Sealer
Does not get hot
the unit does not go into the sealing mode!! what should i do
Aug 07, 2013 | Rival VS230 Seal A Meal Vacuum Food Sealer
When I go to SEAL, it burns a small hole clear thru the bag. One little metal peice on the sealing strip has burned right thru the white heating strip, therefore, it isn't sealing completely.
You need new tape to replace the one presently covering the heat element. You can get a roll of it for just US$7.99. Look at the FixYa question "where [or how maybe] can I get a new tape." I think that you have to be sure that the heat element is flat. I bought a used unit with that problem and the element had somehow gotten bent. Ordered the tape this morning and the cost is worth the hopeful fix.
Jul 30, 2012 | Rival VS230 Seal A Meal Vacuum Food Sealer
When vacuuming out air, the liquid is vacuumed, inside of the bag where it seals is wet, and it won't seal.
Try placing a folded paper towel in the bag between the item and the area of the seal
The towel will absorb the liquid allowing the bag to seal but keeping the liquid in the bag
Feb 05, 2011 | Rival VS230 Seal A Meal Vacuum Food Sealer
The small white clip that keeps the nozzle cage dowmn is broken. Can i get it replaced?
Mine broke too.. I contacted Seal-a-meal, and for my machine, they don't make replacement parts anymore. BUT, here's what I did and it works great. I place a chopstick across the length of the lock and seal nozzle...I use a little scotch-tape to hold it in place.. When you shut the lid, it applies enough pressure to the nozzle, to start pulling air out of the bags. I do have to lean or push down hard on the lid, to get it to lock into place, before sealing, but the chopstick works wonderful...I am not going to buy a whole new seal-a-meal when this works so terrific. In fact, I just seal-a-mealed 8 bags of beans this afternoon. Try it before you go out and buy another machine.
Nov 30, 2010 | Rival VS230 Seal A Meal Vacuum Food Sealer
Rival VS230 Seal A Meal Vacuum Food Sealer Logo
538 people viewed this question
Top Rival Kitchen Appliances - Others Experts
Michael Thomas
Michael Thomas
Paul Carew
Colin Stickland
Colin Stickland
Are you a Rival Kitchen Appliances - Other Expert? Answer questions, earn points and help others
