Question about D-Link AirPlus G DWL-G122 (DHDWLG122) 802.11g/b Wireless Adapter
I recently added on two xbox 360's with wireless capabilities onto my D-link D-524 routers network. One has built in wireless and the other has the wireless adapter with the antennae...they were both able to automatically connect without any configuration. . The problem is that now the other home PC which used to connect to the wireless network before via a D-link GWL-D122 Wireless adapter no longer connects. It is able to detect my wireless network but cannot establish a connection. It says "Windows is unable to connect to the selected network. The network may no longer be i range. please refresh the list of available networks, and try connect again" The comp is in range (4 bars) and I have refreshed and tried to no avail. I tried to open my Dlink Airport Plus app and I go this messege "procedure entry point apsSearchInterface could not be located in the dynamic linklibrary wlanapi.dll" What is happening!? I appreciate any help
Posted by tenjoma415 on
5 Related Answers
Anonymous
  • 53 Answers
SOURCE: [email protected]
Hi , yes it's a known problem and Microsoft/DLink both has confirmed that.
Please download the updated drivers by clicking on the link. below. AS er your information your router's model no. is the 6th entry on the page.DWL-G630_revE. Download and re-install the drivers.
It will fix the problem
http://support.dlink.com/faq/view.asp?prod_id=3002&orig=1
For more information
http://support.microsoft.com/kb/950720
Posted on Jun 05, 2008
Anonymous
  • 538 Answers
SOURCE: D-Link WUA-2340
ahh..ok..try a re install of the dlink software, but get it from www.dlink.com which is almost certainly going to be more current..
Posted on Oct 20, 2008
Anonymous
  • 65 Answers
SOURCE: Cannot connect to my network
If it happens to be a Dell, I think they have a specific configuration or something that has to be changed. For that I'm pretty sure you have to contact Dell, or look on their website.
The way that some routers are set up you have to have a certain pass phrase to access the wireless connection. And make sure, by opening the wireless network monitor, the icon should be in the lower right hand corner by the clock. That you are connecting to the correct user account on the router. Some router configurations require a different user account for each wireless device connecting to it. Or the computer trying to connect you may have to manually select from that menu in the wireless network monitor..
Posted on Nov 27, 2008
Anonymous
  • 71 Answers
SOURCE: D-link DGL-3420 wont work with Xbox 360 and Airport Extreme
For gaming it is best to use WEP personal, if you are try connecting with a computer. A linksys or cisco router is ideal.
Posted on Mar 14, 2009
RescueTechLA
RescueTechLA
  • 2653 Answers
SOURCE: procedure entry point apsSearchInterface error message
Are you getting any led light activity or any kind of indication from Windows (sounds, beeps, chimes) that indicate that it is powering on / being detected?
Posted on Nov 29, 2009
Cant hook xbox 2 wireless router
I'm going to assume that you are talking about the New Xbox 360 Slim that has wireless capabilities. You must go into your settings and go to the network settings. When you choose to connect wireless-ly, choose your routers signal, and if it has a passcode you must enter this in to connect to your router. If you are using the older "fatboy" xbox, you cannot connect to a wireless router unless you purchase the xbox wireless network adapter. Please note that you cannot use the wireless network on the new xbox slim if you have a network cable plugged into your console!
Sep 01, 2011 | Microsoft Xbox 360 Console
Tip
Setup your Xbox to a Wireless Network
Xbox game consoles can be connected <span style="text-decoration: underline;"></span> to a router<a href="http://compnetworking.about.com/cs/routers/g/bldef_router.htm"></a> for wireless access to the Internet and Xbox Live. Follow these instructions to set up the Xbox or Xbox 360 connections to a wireless home network.<br /><br /> <ol> <li>Connect the appropriate wireless network adapter<a href="http://compnetworking.about.com/od/hardwarenetworkgear/g/bldef_adapter.htm"></a> to the console. On the Xbox, a Wi-Fi adapter that connects to the Ethernet sometimes also called a wireless network bridge must be used. Alternatively, the Xbox 360 is also designed to work with certain Wi-Fi <i>game adapters</i> that connect to a USB port.<br /><br /></li> <li>Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -&gt; Network Settings -&gt; Advanced -&gt; Wireless -&gt; Settings" On the Xbox 360, the menu path is "System -&gt; Network Settings -&gt; Edit Settings."<br /><br /></li> <li>Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there.<br /><br /></li> <li>Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.)<br /><br /></li> <li>Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard MS Xbox Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP.<br /></li> <li>Save your settings and verify the network is functional.<br /><br /> On the Xbox, the Wireless Status screen displays whether a connection has successfully been made with the wireless router, and the Connect Status screen displays whether a connection has successfully been made through the Internet to Xbox Live.<br /><br /> On the Xbox 360, use the "Test Xbox Live Connection" option instead.</li></ol> Tips: <ol> <li>Even when your wireless connection between the Xbox and the router is working perfectly, you may still experience difficulty connecting to Xbox Live. These issues can be caused by the quality of your Internet connection or the firewall and Network Address Translation (NAT) settings of your wireless router. Additional troubleshooting may be required in these areas to achieve reliable Xbox Live connections.</li></ol><span style="font-weight: bold;">Troubleshooting</span><br /><br /> The built-in diagnostic of the Xbox can help with any falure.Navigate to the <i>System</i> area of the Xbox Dashboard, select the <i>Network Settings</i> menu option, then select <i>Test Xbox Live Connection</i> to run the test at any time. If the Xbox 360 built-in network diagnostic fails with the following message: <br /> <ul><i>Technical configuration error. Please contact Xbox Customer Support.</i></ul> This indicates a network issue requiring further investigation. The Xbox 360 network diagnostic contains the following tests run in the order listed below. Steps for troubleshooting Xbox 360 connectivity issues depend on which test reports the failure. <br />If you have an original Xbox 360 console, you need to attach an Xbox 360 Wireless Networking Adapter before you can connect your console to a wireless network.<br /> <b>Note</b> You can use an Xbox 360 Wireless Networking Adapter with the Xbox 360 S console. If your wireless router is not near your console, you may get a better wireless signal by using a wireless networking adapter. When you connect an Xbox 360 Wireless Networking Adapter to an Xbox 360 S console, the console will automatically use the wireless adapter instead of the built-in Wi-Fi.<br /> If you have an original Xbox 360 console, you need to attach an Xbox 360 Wireless Networking Adapter before you can connect your console to a wireless network.<br /><br /> Step 1: Attach an Xbox 360 Wireless Networking Adapter to the back of your Xbox 360 console.<br /> Step 2: If a network cable is plugged into the back of your console, unplug it. Step 3: Check the light on the Xbox 360 Wireless Networking Adapter.<br /> If you're using the black adapter with two antennas:<br /> <ul> <li><b>No light:</b> The adapter is not receiving power. Unplug the USB connector, and plug it in again. Still no light? Try plugging the adapter into a USB port on the front of the console.</li> <li><b>Green:</b> The adapter is connected to a wireless router, gateway, or access point.</li> <li><b>Flashing green:</b> The adapter is attempting to connect to a wireless network.</li> <li><b>Red:</b> The adapter is not recognized. Try plugging the adapter into a USB port on the front of your console. </li> <li><b>Flashing red:</b> There is a problem. The adapter might be experiencing a hardware failure.</li></ul><br /> Configure your wireless settings Go to <b>My Xbox,</b> and then select <b>System Settings</b>. <br />Select <b>Network Settings.<br /></b>Select <b>Configure Network</b>.<br /> <ol> <li>On the <b>Basic Settings</b> tab, select <b>Wireless Mode</b>. <br /> <b>Note</b> If Wireless Mode is still not available, there might be a problem with your hardware. <br /></li> <li>Select <b>Scan for Networks</b>. </li> <li>Select your wireless network name. <br /><br />If your wireless network is not listed, try either of the following:<br /> <ol> <li>Try improve the router signal by moving the router position.If you are not broadcasting your wireless network name, select <b>Specify Unlisted Network</b>, and enter your wireless network name and security type. </li></ol></li><br /> <li>Enter your wireless network password, and then select <b>Done</b>.</li> <li>Press the <b>B</b> button on your controller, and then select <b>Test Xbox LIVE Connection</b>. If you successfully connect to Xbox LIVE, you'll see this screen:Choose <b>Yes</b> when you are prompted to update the console software. <br /></li></ol>
on Jan 18, 2011 | Video Game Consoles & Games
Am trying to get xbobx live for my nephews birthday, hes got the xbox 360 ellite, but its not the shinny latest model do i need a wireless adapter as well as the router that came with my broadband, but we...
If you do not have a router that you can plug directly into the back of the Xbox 360 then yes you will need to purchase a wireless router to sync up with your wireless router that you already have downstairs. You didn't specify if your broadband router had wireless capabilities? Does it? If not then you will need to buy a wireless router to be able to hook up your Xbox 360.
Microsoft has their own personal wireless router that fits on the back of the Xbox 360 nicely. I would recommend you purchase it due to ease of installation and compatability.
Here is a link to an example of what it looks like: http://www.gamestop.com/xbox-360/accessories/xbox-360-wireless-n-networking-adapter/76045?ref=recpdp&cross=802124
And a cheaper older model: http://www.gamestop.com/xbox-360/accessories/xbox-360-wireless-network-adapter/40678
And here is a link to Xbox step by step wirless hookup: http://support.xbox.com/en-us/pages/xbox-live/get-started/connecting/wireless.aspx
If you are having specific issues then ask away and I can see what I can do to help you out. Try to be specific on what your current setup is and what problems you are having. thanks.
Jul 16, 2011 | Microsoft Video Game Consoles & Games
My xbox 360 cant pick up my wirless connection do you no why ?
have you got a new xbox 360 or old xbox 360 as the old version doesnt have wireless built into it
Mar 12, 2011 | D-Link AirPlus DI-524 Wireless Router
I have installed it onto my computer and done everything the manual says and I have the USB model WNA3100. On the box it says that it is capable of connecting to consoles to support multiplayer gaming. I...
In order to do that you would have to plug this into your xbox 360, not your computer. HOWEVER, Microsoft only supports their own wireless adapter for the xbox 360 .... this one: http://www.amazon.com/Xbox-360-Wireless-Network-Adapter-Networks/dp/B000B6MLV4
I have also heard that wireless gaming can have lesser results. But if you want to do Xbox Live wireless, you will have to have a router and Microsoft's XBOX wifi adapter shown in the link above.
To connect to Xbox live, your best bet is to (if you dont have one) get a router, connect it to your Internet modem, and plug it into the xbox 360 using an ethernet cable.
Mar 08, 2011 | NetGear WirelessN 300 USB Adapter WNA3100
I have a d-link DI-524 router and i need to open all ports so i can use my xbox 360 online, Help
Is there any computer connected to the router ?
If not then connect the computer to the router.
check the IP address and the default gateway of the router.
open the set up page of the router.
there you will find the place to place to open the ports on the router.
Click Here for more information about roters and network
Jan 29, 2010 | D-Link AirPlus DI-524 Wireless Router
I have a DI-524 router. Our xbox 360 nat won't stay open
If you have other comps running while he is playing, especially streaming, there may not be enough bandwidth.
Nov 14, 2009 | D-Link AirPlus DI-524 Wireless Router
Link Your Console to Another Console
Console-to-Console Connection: Wireless Some Xbox games offer console-to-console, or system-link, play, in which two or more players (depending on the game) can wirelessly network their consoles for multiplayer use. Console-to-console wireless networks are also known as ad-hoc networks. In ad-hoc networks, a wireless adapter on one device connects directly to a wireless adapter on another device. An Internet connection isn't shared with this type of network, and the console-to-console connection is typically temporary. For console-to-console play, you need: Two Xbox 360 consoles. Two Xbox 360 Wireless Networking Adapters. An Xbox 360 game that supports system link play. To wirelessly connect your console to another console: Attach an Xbox 360 Wireless Networking Adapter to the back of each console as described in Use Your Xbox 360 Wireless Networking Adapter. On each console, go to the System area to enter your network settings. (They will be the same for each console.) If all settings are correct, exit the System area. The consoles should now be wirelessly connected to each other.
Nov 20, 2005 | Microsoft Xbox Console
D-Link AirPlus G DWL-G122 (DHDWLG122) 802.11g/b Wireless Adapter Logo
85 people viewed this question
Top D-Link Computers & Internet Experts
Mike
RockTheHood
k24674
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
