There are adjusters on the brake cables that are designed to solve this problem. The cables for the brakes run inside a flexible housing. When you squeeze the handle, the cable should engage the brake. The problem is that the cables inside the housing stretch over time and do not work as well. There is a threaded adjuster at the handle where the housing of the cable goes into the handle. If you turn this adjuster counterclockwise it will, in effect, make the housing longer and the brake cable tighter (shorter). This should engage the brakes better. It make take some trial and error, turning the threaded adjusters clockwise and counter-clockwise to get the proper setting for your strength and comfort. This same adjustment technique applies when you pull the handles down in the park position and when you squeeze them to slow down. Hope this helps.
The automatic transmission shift lock control switch.
The park/neutral position switch.
With the ignition in the ON position, battery positive voltage is supplied to the park/neutral position switch. When the transmission is in the PARK position the contacts in the park/neutral position switch are closed. This allows current to flow through the switch to the automatic transmission shift lock control switch. The circuit continues through the normally-closed switch to the automatic transmission shift lock control solenoid. The automatic transmission shift lock control solenoid is permanently grounded. This energizes the automatic transmission shift lock control solenoid, locking the shift linkage in the PARK position. When the driver presses the brake pedal the contacts in the automatic transmission shift lock control switch open, causing the automatic transmission shift lock control solenoid to release. This allows the shift lever to move from the PARK position.
Park Lock Solenoid
The park lock solenoid is a safety device that prevents an inadvertent shift out of PARK when the key is in the OFF position. The key must be in the RUN position to release the park lock solenoid. The system consists of the park lock solenoid. With the ignition in the ON position, voltage is supplied to the park lock solenoid. The park lock solenoid energizes through a permanent ground unlocking the shift lever. With the ignition in the OFF or ACCY position the park lock solenoid de-energizes and locks the shift lever in the park position.
Shift Lever Does Not Move with Brake Pedal Depressed
DEFINITION: Transmission shift lever will not move out of the PARK position with the ignition ON and the brake pedal pressed.
Did you perform the Symptoms - Automatic Transmission Shift Lock Control tests and all the necessary inspection?
Go to Step 2
Go to Symptoms - Automatic Transmission Shift Lock Control
The brake to shift relay
The rear integration module (RIM)
With the ignition in the ON position, battery positive voltage is supplied to the brake to shift relay coil. When the RIM energizes the brake to shift relay, the brake to shift relay switch contacts close suppling battery voltage to the automatic transmission shift lock control switch. The circuit continues through the normally closed switch to the automatic transmission shift lock control solenoid. The permanently grounded solenoid is energized. This locks the shift linkage in the PARK position. When the driver presses the brake pedal, the contacts in the automatic transmission shift lock control switch open. This causes the automatic transmission shift lock control solenoid to release. This allows the shift lever to move from the PARK position.
With the ignition in the ON position, battery positive voltage is supplied to the brake to shift relay coil. When the RIM energizes the brake to shift relay, the brake to shift relay switch contacts close suppling battery voltage to the automatic transmission shift lock control switch. The circuit continues through the normally --closed switch to the automatic transmission shift lock control solenoid. The permanently grounded solenoid is energized. This locks the shift linkage in the PARK position. When the driver presses the brake pedal, the contacts in the automatic transmission shift lock control switch open. This causes the automatic transmission shift lock control solenoid to release. This allows the shift lever to move from the PARK position.
Shift Lever Does Not Move with Brake Pedal Depressed ?
