Danby 3.6 cu. ft. / 102 liter Chest Freezer Millenium DCF401W Logo
Ted Colbourne Posted on Nov 22, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Every week the freezer shuts off and we have to turn it completely off and start it again. the freezer is only one month old.
Anonymous
Level 3:
President:
  • Master 1,218 Answers
  • Posted on Nov 22, 2010
Anonymous
Master
Level 3:
President:
Answers
1218
Questions
Helped
276963
Points
3870
Good day,
This issue should be left up to the manufacturer. Everything on the machine is under warranty.
Call You selling dealer on how to get a warranty call set up. It should be free to you.
1helpful
I have a Danby DUF808WE upright freezer. It works for a while (days/weeks)then stops. If I wack it on the top it starts up again and runs again. What do you think the problem is?
In that model the Temperature Control often is the culprit.
When the freezer gets very cold it shuts off.
The because it is not running it gets warmer and will start to work again.
I would perhaps focus on the Temperature Control.
2answers
FREEZER quits working and if you unplug it and plug it back in will start working and work for weeks and may quit again.
If it has the control board on the door, they have been known to do that, it pressed/snapped into the door. If not and it has a manual ,standard knob on the inside, thermostat , slowly turn it back and forth to hear the clicking of the control which should start and stop the operation. If this is a self defrosting freezer and has the thermostat it also has a defrost timer that like a alarm clock shuts the unit on and off for 20 min intervals every 6 to 8 hours, this part has a little motor on it that overheats. You will be able to physically see oil comming out of it, or noisy ticking/ humming and very hot to the touch. Replace these parts and it should repair it. Good luck
FREEZER WILL DEFROST AND THAW OUT FOOD. THEN WILL START FREEZING AGAIN IN A COUPLE OF DAYS. THIS HAS HAPPEN 3-4 TIMES IN LAST 6-8 MONTHS. WHAT COULD BE PROBLEM?
seal around freezer door may be warped/old/cracked... or thermostat is not working properly.
Try duct taping door as tightly shut as possible and check around the time it freezes to see if that fixes the problem. If so, the seal (that has magnets so it will seal completely) needs to be replaced.
If that doesn't fix the problem, it could be a faulty thermostat in the freezer.
My freezer will freeze for about 2weeks then it starts to get warm when I turn it off for about 6hrs it will refreeze
It sounds to me like the defrost isn't working somewhere.It freezes for 2 weeks until the evaporator coil freezes over and you lose your airflow, hence, your cooling. Then when you shut the unit off for 6 hours it thaws out enough to get you cooling again for 2 weeks.Check your defrost timer and see if it is going into defrost and if your defrost elements are good. Both will be located on top of the unit. Good luck!
Ice forming very fast on top shelf only
You said you checked the seal but one thing you can try to be double sure the seal is tight put a thin layer of vaseline along the entire seal it will fill in any gaps and you can be sure it is sealing completely.
Freezer won't start after defrost cycle
It might be the timer motor, if it doesn't run. neither does the timer. Easily replaceable and cheap. good luck. John
Freezes for 7 to 14 days then just quits!
hate to tell you but your compressor is going out on your freezer ,,, i'd look for another freezer.
Larry
Frigidaire Chest 5 cu ft Making Fan noise & will not turn on...6 yrs old.
at 6 years old it certainly aint new!
from what you describe, sounds like a compressor fault
2answers
Freezer does not work
almost certainly a problem with the defrost timer - just replace complete. doesn't matter what position you set timer to when replaced
1helpful
Top Danby Freezers Experts
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Thomas Perkins
Thomas Perkins
Are you a Danby Freezer Expert? Answer questions, earn points and help others
