-you can check the cables on the monitor have it disconnected and reconnected
-if it still does it try another monitor cable
-one way you can check is to use a flash light by shining it on the screen and look closely to see if you can see any images .
-try touching the menu screen on remote to see if you can see image, if you can then the lcd screen is bad and would need to be replaced. the same would be if you cant see any image =
