Question about Redhead Pursuit (18-36x50)
We need 2 know what 4 m o a means - Redhead Pursuit (18-36x50)
Posted by longcut8044 on
Anonymous
    Sniper:
  • 58 Answers
MOA is the abbreviation for Minute of Angle, which measures 1/60 of 1 degree. If you want all the technical jargon and math that involves, this link explains it all: http://en.wikipedia.org/wiki/Minute_of_angle
But when you're talking about rifle scopes, here's what you need to know:
Adjusting the angle of your scope by 1 MOA will change the point of impact by about 1 inch at a distance of 100 yards. So 4 MOA is roughly 4 inches over on an object viewed at 100 yards.
Usually, the windage and elevation adjustments on a scope will be about 1/4 MOA, or about a 0.25 inch change over 100 yards.
Posted on Jan 14, 2011
How can I find the mean absolute deviation?
Mean absolute deviation.
Let's break it down into its components.
Mean - Average
Absolute - absolute value - sign doesn't matter - if negative, make positive
Deviation - difference from the mean
Let's do an example. Population 3 7 4 2. Total 16. Mean (Average) 16/4 = 4.
Deviations
3 - 4 = -1 absolute value 1
7 - 4 = 3
4 - 4 = 0
2 - 4 = -2 absolute value 2
Sum of these deviations 1 + 3 + 0 + 2 = 6
Mean (average) of these deviations is 6 / 4 = 1.5.
Good luck,
Paul
Apr 05, 2016 | Texas Instruments TI-30Xa Scientific...
How to find the mean absolute deviation
Add all the numbers together to get the sum.
Divide the sum by the number of numbers to get the mean.
so you have
1,2,3,4, that is 10. divide ten by four. because there are 4 numbers.
you get 2.5. Take each number and subtract 2.5. Discard all the negatives from the pile. So in essence you are taking the above example and subtracting 2.5 from 3 and 4 because the other two are going to be negative. so the answer is 3 - 2.5 and 4 - 2.5 which is 2. then take that 2 and divide by the number of items that you subtracted from which is 2. 2/2 is 1. one is the mean standard deviation.
Apr 17, 2014 | Acer Computers & Internet
I have a sunbeam slow cooker model # 2690 . I do not have the manual and would like to know what dial settings mean. there is off , then I , then II , then a weird diagram .
I is low
II is high
the diagram means that this setting does 2 hours on high then 4 on low. i think its 4 on low but i know for sure its 2 on high
Aug 09, 2011 | SUNBEAM PRODUCTS Crock-Pot® Slow Cooker...
2 or 4 cycle oil for a Ranch King 6.0 lawn mower? What kind or type of oil should use?
If you mean oil for the crankcase use need 4 cycle oil Ususally 30 weight and don't over fill Most small engine do not even take a quart only about 20 oz.
If you mean to mix with gas ( I doubt this) but then you need 2 cycle oil depending on the mixture usually about 3 oz to a gallon of gas (3.2 oz / gal = 40:1 ratio, 2.5 oz/ =50:1)
May 24, 2011 | Briggs & Stratton Garden
How can i run 4 monitors to put out one total screeen.. ok lets say i take 4 montiors and put like two 15" monitors and stack them with antoher 2 under it so its a box of 4 .. 2 screens wide by two...
In order to do this, hardware wise, you would need 4 monitors and enough graphic ports to support them.
Older graphics cards may only have two graphic ports which means you would need to have 2 videos card installed on your machine in order to get 4 displays going.
On some of the new graphics cards, you can get as many as 8 ports on the same card meaning you could drive 8 displays with one cards.
Once you've got the right hardware, you can either use the manufacturer's software (ATI or nVidia most likely) to configure your monitors to run as one desktop or you can try using Windows built-in display settings. The key is you want to extend your desktop onto all the monitors and to tell your computer which screen you want where.
If you need any more help with that, let me know.
Mar 25, 2011 | Samsung Computers & Internet
When I substract log(2) from log(4) I get .301029957, the answer should be 2, what is wrong?
The answer for the problem log(4) - log(2) is actually 0.301, so the good news is that your calculator is working properly! Here's a quick breakdown of the solution for the problem:
1) We know that log(x) = N means that 10^N = x. So in this case, we need to find a number that 10 can be raised to in order to get 4 and 2.
2) To get a better idea of what the answer to the problem will be, we look at the scale of the numbers. 4 and 2 are both smaller than 10. In order to raise any number to a power and get a smaller number, that power must be less than 1. If the power was 1 or greater, the answer would be more than 10. Therefore, we know that log(4) is a decimal less than 1 and log(2) is a decimal less than 1.
3) Now we'll simplify the problem. A logarithm rule states that:
log(x) - log(y) = log(x/y)
We can use this rule to simplify the equation in the problem.
log(4) - log(2) = log(4/2)
Since 4/2 = 2,
log(4) - log(2) = log(4/2) = log(2)
4) Now to solve the equation, the only thing that must be calculated is log(2). This would be done on a calculator. In step 2, we analyzed that log(2) must be less than 1. Therefore, the calculator is correct with the answer 0.301.
Hope this helped!
Nov 30, 2010 | Texas Instruments TI-84 Plus Calculator
I have a mitsubishi model wt42311 TV that will not stay on. The error code is 2 blinks a pause and 2 blinks. What needs to be fixed?
2,2 is short protection---it means one of the two soldered in fuses that protect the convergence circuit is bad.
What it really means is both of the STK-392-110 convergence chips this set uses need to be replaced---one of them got the fuse.
May be a do it yourself job if you know how to solder etc. Total parts cost should be under 30 dollars.
Let me know if I can assist you further.
SD TECH
Jan 23, 2010 | Mitsubishi WT-42311 42" Rear Projection...
I guess he needs to know what kind of oil he needs also
you shouldn't need to mix oil with gas on a four cycle engine. this is for two strokes.
Aug 23, 2009 | Garden
Which cylinder in #6 on a 2006 V6 hyundai sonata
Autozone.com says that for this vehicle the firing order is 1-2-3-4-5-6 and the set-up is 2/1 4/3 6/5 meaning that the #6 cylinder is far right on the back. It goes #1 #3 and #5 in the front and #2 #4 and #6 in the back.
Jul 18, 2009 | 2007 Hyundai Sonata Limited Sedan
Need to know where to put the oxygen sensor
you have 4 sensors. bank 1 sensor 1 - bank 1 sensor 2 - bank 2 sensor 1 - bank 2 sensor 2. it depends on which one is defective.
May 01, 2009 | 2001 Lexus Gs 300
Redhead Pursuit (18-36x50) Logo
161 people viewed this question
Top Redhead Optics Experts
Marvin
Marvin
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Redhead Optic Expert? Answer questions, earn points and help others
