Question about Mitsubishi WD65737 65" DLP TV
I am getting white and black spots in the picture. More are appearing as time goes by.
Posted by shelbygi on
Shawn O'Halloran
  • 345 Answers
Could be many things: mirror hinge fatigue, dust mircromirror device (MDM). You need a service tech.
Posted on Nov 23, 2010
Sony videoscope xbr
would think you need to replace the cable board etc. the signal is not getting in and out right. can also be a fault on the power board giving the wrong volts so would check this to. it will tell you on the board what volts is supposed to be. the 5v and 12v should be spot on other volts will vary a little. also check the capacitors for the caps to be bowed up and a brown/ yellow gunk around them and under the board this can be a sign they are failing.
Feb 25, 2014 | Televison & Video
I have black spots on my Panasonic Lumix DMC-ZS8 lens camera
If you want to know if these spots are on the sensor. Or you want to exclude this, You could try this:
Put the camera in A priority. (manual mode). Turn the aperture to the highest setting. Greatest figure like f 22 I can't find the exact figure. It could be it is only 8. Then in a bright light, take a picture of a white sheet of paper. The picture that comes out, should be checked on dark spots. If they are there the spots are on the sensor. If you can't find the spots on the white picture, something else is wrong.
Feb 12, 2014 | Panasonic Lumix DMC-ZS3 Digital Camera
I just bought a Westinghouse LED TV. When I hooked up my dual DVD/Video combo the picture is black and white. What did I hook up wrong??
It sounds like you may have connected the dvd/video combo to the wrong spot on the television. The yellow wire cannot be placed into the green hole. You'll get a picture but it will be in black and white. You can only connect these yellow, red, and white composite wires to a component input spot on this television in order to get a color picture.
Aug 21, 2011 | Televison & Video
I am getting white spots that are appearing on the display image. It started out with one but now there's more every day. Is this fixable? Is there dust maybe ibside the lens? Is the bulb going? The...
I feel Most of DLP's getting this issue. Please tell me If the black & white dots are blinking....
To see it you need to put very clearly focused A4 sheet. If some dots are blinking .... most of time DLP chip is bad or getting bad.. IF can please upload a very clear picture......
Jul 30, 2011 | Optoma DLP Projector Multimedia Projector
For KDF-E42A10 When picture is black, a bluish fadded spot appears in the center of screen. When picture is white, a yellowish fadded spot appears in the center. Do I just replace the bulb?
no this is a problem with your Optical block your LCD chips have gone bad you need to replace this part to fix this issue the bulb will not solve this kind of issue
Oct 15, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Mitsubishi dlp tv WD65733 has white spots, like stars on screen, what causes this
If you get White or black dots all over the screen (DMD symptom)
If you get a pixilated picture (DMD Board)
Mar 27, 2010 | Mitsubishi WD-65733 65" HDTV
White spots appear about 8 in 2 weeks will it keep getting worst all at once or over along period of time
yes it will keep geting worse the dlp is is going bad the mirrors on it are getting stuck they may appear as black dots or white dots. the dlp ic needs to be replaced
Jan 29, 2010 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung dlp tv. white dots scattered across the screen. never change, always same spots. also appears to have some black dots
your dlp ic is going bad and needs nto be replaced. some of the mirrors are getting stuck they will appear as black dots or white dots. it usually starts as one or two and will continue to get worse over time.
Jan 28, 2010 | Samsung Televison & Video
White Spot
If this white spot is always exactly the same, but moves off the picture when you start to digital zoom and not optical zoom, there is probably something on the sensor. You mentioned that when zooming, eventually it moves. Are you in digital zoom mode at that time? (The switchover from optical to digital zoom is automatic, but you can disable it). Is this white spot blurry or sharp? Can you see fringes of the image at the edges? (This would suggest something on the lens).
If there is a piece of dust inside the lens ,you may be able to see it looking down the lens. How big is this spot?
Either way, if the camera is new, can you still return it?
May 28, 2008 | JVC GR-D244 DV Digital Camcorder
Mitsubishi WD65737 65" DLP TV Logo
283 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
