Hyundai Electronics E320D 32 in. LCD Television Logo
Question about Hyundai Electronics E320D 32 in. LCD Television
I have a E320D 32 inch Hyundai, the problem with the t.v is it started to flicker with no sound when switched on, however once the t.v warms up it stops flickering. It has been doing this for a while now and i`m wondering if I should get it fixed or just buy a new t.v depending on what sort of problem it [email protected]
Posted by martin george on
Anonymous
    New Friend:
I got the same problem, did you find a solution to this?
Andrew
Posted on Dec 29, 2010
  • 1 more comment
  • Anonymous Feb 13, 2011
    Hi Andy,
    Check out the post here:
    http://www.fixya.com/support/t1121498-hy...
    SJ
    Hi, Thanks for the link, I'd seen this one before, unfortuantly all the screws are screwed in tightly, Like the original poster I get a flickering picture on any source and no sound until the tv warms up, some days its only 10 mins, some an hour other days all day.
    Oh well, worth mentioning anyway! Definately sounds to me like a power rail regulation issue (or of course a dry joint somewhere ), but as it is on all sources, my money is on a duff PSU. Can you stick an osciloscope on the PSU outputs? - It is more likely to be one of the higher voltage outputs (Plus or minus 12v or more). Again, my money would be a buggered elecrolytic cap. SJ
Nothing on screen but there is sound
chek power inverter board. and find inverter driver
2helpful
Faulty remote control
Yes,Try website like Remotes.com to buy an exact orginal remote for the replacement.
My remote control for my hyundai lcd tv is broken and the power button on the tv doesnt work either is there a remote that i can buy that will work straight away
try charles hyde and son web site (CHS) or amazon if still got old remote will need model number
if not can find with tv make and model number
1helpful
Hyundai E320D 32 in. LCD Television , No signal fault
I had exactly the same problem with mine this week. After taking the back off and poking about with my multimeter (I am an electronics engineer!) I discovered that the power supply board is screwed to the chassis with 4 screws (three of which are system grounds(earth)). All three of the earthing point screws had worked their way loose - The fourth (top left as you look from the back) was still tight, but this one does not ground the board. After tightening these back up the television is now working fine again. - so fingers crossed! I will report back to this thread if it stops again! Please post here if you have the same fault and it does or doesn't fix it. Sparky Jay
Top Hyundai Electronics Televison & Video Experts
Marvin
Marvin
Are you a Hyundai Electronics Televison and Video Expert? Answer questions, earn points and help others
