Fusion ENAM30020 Car Amp Logo
Posted on Nov 21, 2010
Amp comes hit hard then loses power 5 seconds come back hitting even harder then goes out again
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 12, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
91
Points
What kind of voltage regulator is in the fusion 300 wat amp
Tried unpluging and nothing tried al buttons nothing the computer was at a shop to BE FIXED AT SHOP OK CAME HOME STUCK IN POWER SAVE MODE BUTTON ORANGE ON MONITOR HIT GOES GREEN SAYS PAWER SAVE MODE HIT...
Press and hold the power button for 5 seconds this will turn the system completely off wait 5 seconds then turn it back on as soon as it boots up go into power options in the control panel and click the option from power saver mode to do nothing as there is a fault with some computers that it gets stuck in power saver mode
I have a 52" RCA
The deflection board needs replacement. You need the PSB260 deflection board available from www.tvrepairworld.com
Hi I have a 27 C240 Sharp tv that the picture rolls vertically on. If I hold the channel change button or any button while in menu mode with the remote, it shuts off and will only come back on after...
hit your TV lightly on left side or right side or on top & then observe ..........you will get normal picture or it comes & again it goes....if it is happening like that then following is the situation..........after 4 or 5 yrs in some TVs on main board ( also on CRT circuit board ) at some soldering joints crack develops....then due to loose contact picture becomes small in size or abnormal width, or rolls etc ...........when we hit that lightly then those loose contacts joins temporarly & again picture appears normally for some time............so solution is .....TV main board & CRT circuit board should be observed carefully & most of the joints should be re-soldered.......only a good service engineer can do that........even after hitting TV lightly if there is no response then main board has to be checked completely........in your case iam sure it is loose connection problem.........joints should be re - soldered ...100% it works again ................this problem cannot be solved by user unless user has idea about components( resisitors, transisitors, diodes,...etc) , have soldering iron , multimeter & other tools....................so contact good TV service engineer .............iam from bangalore - 09986222774 - [email protected] ( computers, laptop, printers, etc ).
17'' samsung synchmaster 794MG model display but screen shrinks from all sides ,After few seconds display becomes very small just about in single inch size .
hit your MONITOR lightly on left side or right side or on top & then observe ..........you will get normal picture or it comes & again it goes....if it is happening like that then following is the situation..........after 4 or 5 yrs in some monitors on main board ( also on CRT circuit board ) at some soldering joints crack develops....then due to loose contact picture becomes small in size or abnormal width,etc ...........when we hit that lightly then those loose contacts joins temporarly & again picture appears for some time............so solution is ......monitor main board & CRT circuit board should be observed carefully & most of the joints should be re-soldered.......only a good service engineer can do that........even after hitting monitor lightly if there is no response then main board has to be checked completely........in your case iam sure it is loose connection problem.........joints should be re - soldered ...100% it works again ................this problem cannot be solved by user unless user has idea about components( resisitors, transisitors, diodes,...etc) , have soldering iron , multimeter & other tools....................so contact good monitor service engineer .............iam from bangalore - 09986222774 - [email protected] ( computers, laptop, printers, etc )..............
1helpful
I have a 2003 vulcan classic 1500. When I turn on the ignition switch the power comes on but when I hit the starter everything goes dead.After a few seconds with the switch left on the power comes back on...
Did you load test or just volt check on battery? Sometimes they will short the plates partially, still giving good voltage and will still operate low amp devices such as a light. Usually happens w/ age or improper servicing of a new battery
5helpful
2answers
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
1helpful
Can not remove MEMORY CARD from canon a540
Pull it harder. You obviously don't want to break it but if it still doesn't come out, I would look for screws and try to take the camera apart. Take the battery out first and don't forget how it goes back together and it should be fine.
2001 Nissan Maxima loses power at 40 MPH.
Fuel pump is not pumping hard enough anymore. Have a mechanic check the pressure. Either pump is bad or the fuels filter is clogged. One other thing that causes this is a clogged Calalytic Converter.
Added another amp to system now subs dont hit as hard
This sounds odd, but try putting your subs out of phase from the mains. Just see if it changes anything.
Top Fusion Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Fusion Car Audio and Video Expert? Answer questions, earn points and help others
