Pres f 9 to choice boot menu. Or go F 10>go bios for set boot piority>and F 10> yes enter.if not work please re install xp .and create partion again ,because your kids can be delete the partion file (ntldr/boot.ini).
Disc will not start up. None of the F's work.
I think you are ussing vista if so that
I suggest trying the following methods to troubleshoot the issue:
Method 1: Startup Repair from the Windows Recovery Environment (WinRE)
1. Insert the Windows Vista installation disc into the disc drive, and then start the computer.
2. Press a key when the message indicating "Press any key to boot from CD or DVD …". appears.
3. Select a language, a time and currency, and a keyboard or input method, and then click Next.
4. Click Repair your computer.
5. In the System Recovery Options dialog box, choose the drive of your Windows installation and click Next.
6. At the System Recovery Options Dialog Box, click on Repair your computer.
7. Click the operating system that you want to repair, and then click Next.
8. In the System Recovery Options dialog box, click Startup Repair.
Method 2: Rebuild BCD
1. Put the Windows Vista installation disc in the disc drive, and then start the computer.
3. Select a language, a time, a currency, and a keyboard or another input method, and then click Next.
5. Click the operating system that you want to repair, and then click Next.
6. In the System Recovery Options dialog box, click Command Prompt.
7. Type Bootrec /RebuildBcd , and then press ENTER.
Method 3: Use the Windows Recovery Environment (WinRE) to run System Restore ============================================
6. At the System Recovery Options Dialog Box, click on System Restore.
7. Follow the System Restore Wizard instruction as usual and choose the appropriate restore point.
8. Click Finish to restore the system.
Hope it will help you.
best regard shibuda
If you want to more equipment follow the pagehttp://www.howtogeek.com/howto/windows-v...
I have Windows XP and when I put in the recovery disc nothing happens it stays on the blue
hp screen. No matter what I do the HP screen is stuck on.
PLEASE WRITE STEP BY STEEP WHAT YOU ARE LOOKING.IF SEE F1 :PLEASE HIT F1.
THEN YOU CAN SEE BOOT MENU OR GO FOR BOOT MENU.ANY HOW TELL ME NOW ONCE AGAIN PROPER.
Since you have a copy of XP CD,please Boot from that CD, delete all partitions and create and format a new partition, install XP. Go for bios setting, he BIOS or Basic Input/Output System is the basic controller that allows all of the components that make up a computer system to talk to one another.HP
* Press the F1 or F10 key after restarting the computer.
* HP Tablet PCs may use F10 or F12.
* Other HP computers may allow access to BIOS using the F2 or Esc keys for back.You may need to access the BIOS setup utility for a number of reasons like managing memory settings, configuring a new hard drive, changing the boot order, resetting the BIOS follow link=http://pcsupport.about.com/od/fixtheprob...
note ;you should Load BIOS Setup Defaults( dont panic.)
Here are some common things you can do in most BIOS setup utilities:
* Change the Boot Order
* Load BIOS Setup Defaults
* Remove a BIOS Password
* Create a BIOS Password
* Change the Date and Time
* Change Floppy Drive Settings
* Change Hard Drive Settings
* Change CD/DVD/BD Drive Settings
* View Amount of Memory Installed
* Change the Boot Up NumLock Status
* Enable or Disable the Computer Logo
* Enable or Disable the Quick Power On Self Test (POST)
* Enable or Disable the CPU Internal Cache
* Enable or Disable the Caching of BIOS
* Change CPU Settings
* Change Memory Settings
* Change System Voltages
* Enable or Disable RAID
* Enable or Disable Onboard USB
* Enable or Disable Onboard IEEE1394
* Enable or Disable Onboard Audio
* Enable or Disable Onboard Floppy Controller
* Enable or Disable Onboard Serial/Parallel Ports
* Enable or Disable ACPI
* Change the ACPI Suspend Type
* Change the Power Button Function
* Change Power-on Settings
* Change Which Display is Initialized First on Multi-Display Setups
* Reset Extended System Configuration Data (ESCD)
* Enable or Disable BIOS Control of System Resources
* Change Fan Speed Settings
* View CPU and System Temperatures
* View Fan Speeds
* View System Voltages
you can only change as first boot cd rom drive 2nd hdd
then save by f10 ensure your xp cd in the cd tray.the cd drive run first or enter once
install again delete c drive just select the drive (c)>enter >L>for create select the unpartition size >C>dont change the size>enter>try to select fat32 (quick)
i youhave proffetional follow the linkhttp://windows-xp-full.net/Que-Exam.Cram...
or you have home edition http://www.networkcert.net/xp/install.ht...
after installation go download driver http://h10025.www1.hp.com/ewfrf/wc/softw...
Power went out for a few hours now it works fine. I have no idea what happened but thank you for helping.
I am no expert at all but I managed to fix my son's computer by choosing the F10 key for rebooting the notebook. So pleased I can tell you! Select F10 and select boot options. For some reason the computer was trying to start up using the Optical Device Drive first and the Notebook Hard drive second. Once I changed them by using the Enter key to Notebook Harddrive first and Optical Hardrive second, it worked!!!! Save the changes by following the menu and pressing F10 to exit. The computer started back up as normal and went on to XP, etc, etc.
hope this helps
