Full tank so what can i do - Computers & Internet
Posted by soodays on
ikkenom
    Brigadier General:
  • 10,406 Answers
> full tank, so what can I do?
Are you saying that the ink-cartridges in your printer are full, and that your ink-jet printer is still not printing?
If so, use the software that came with the printer, to run a "print-head-cleaning" cycle,
to "unclog" the ink-jets that pull ink from the tank and shoot the ink onto the paper.
Posted on Nov 21, 2010
Gas tank will not fill up on 2001 ford expedition
Gas as in gasoline or gas as in LPG gas? If its petrol, the fuel sender may be out of adjustment. (Usually means a new sender) If its LPG, the fuel stations are set to automatically shut off at 80% full. The gas tank will never actually be full to the brim but the gauge should be showing full if the gas nozzle keeps shutting off. Have a look on the LPG tank itself, they have a little gauge on them which shows how full it is. I have 2 tanks on my car , when "full" or when the pump shuts down, the tank gauges show just under full but the gauge on the cars dash shows full (2005 BA Ford)
Feb 18, 2015 | Ford Expedition Cars & Trucks
Hi I have problems with my mitsubishi dehumidifier Oasis Elite MJ-E-142NX-A1 The water tank full light stays on even though the tank is empty. I have emptied the water and replaced the container care
Sounds like your float is stuck in the full position, or the sensor that shows full is stuck on full.
If tank is empty but shows full, problem lies where full signal is coming from.
Aug 19, 2014 | Dehumidifiers
When i am trying to put a full tank of gas it stops pumping when it's not full
Assuming your gauge is accurate, if the tank is not taking gas it usually has a restriction in the neck or a venting problem.
Any chance your tank is full and the gauge is off ?
Jul 02, 2012 | Cars & Trucks
Fuel gage goes from full to emty all the time. when it first stated it only did it with quater tank or less.
Sounds as if the SENDING UNIT in the tank is faulty. They work by RESISTANCE, so when the contacts on the fuel guage sending unit in the tank get worn, it will send incorrect data. Typically it will say full when the actually IS full, then, when the tank is 3/4 full, it will say EMPTY, and then, as you use more fuel from the tank, the guage will go from what is REALLY in the tank, to empty, at different times.
Only solution is to remove the fuel tank, and replace the sending unit guage assembly.
Jun 11, 2011 | Oldsmobile Aurora Cars & Trucks
I have a samsung clp500 color printer but it is not working .it show only waste tank is full/ not instaled what should i do.
The "waste tank" is located behind the front panel that has the SAMSUNG name on it. Press on the upper corners of this panel and it will open up to reveal a clear plastic tank on the right side.
This tank pulls out easily and has two holes for excess toner to flow into it.
Look at the side of the tank that has the holes. You should see a part of the tank that extends out from the tank but ends in a clear square. The waste tank sensor "looks" thru this clear plastic square to determine if the tank is full. I.e. if toner is in this area and you cannot clearly see thru both sides, the sensor will tell the printer that the tank is full and needs to be changed.
If the tank is not full, use a long cotton swab and clean out the inside of this area. Once you can see thru both sides, carefully replace the tank back into the printer and turn the printer back on.
If done properly, the error should go away and you should be able to continue printing. I have doen this and it works fine.
(Some posts have had people cut this part of the tank off and simply tape over the hole that is made with strong tape. This bypasses the sensor and would allow the printer to run again. I have not done this as I do not want the possibility of toner spilling in my office.)
Exception:
The sensor could be bad and causing the issue. If this is the case, it may be cheaper to purchase a new printer - CLP-620 ND is a duplex, networked color laser jet that is selling from frys.com for $315.
Apr 30, 2010 | Samsung CLP-500 Laser Printer
Indicator says "tank full"
The switch is the most likely problem,check the switch with a multimeter
Apr 03, 2010 | Amana D545M Dehumidifier
Tank absorber full and lights blinking
The POWER Lamp Flashes Orange Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact a Canon service representative.
Note
Canon recommends that you call for service as soon as this error occurs. Once the waste ink tank becomes completely full, printing will no longer be possible.
Sep 14, 2009 | Canon i350 InkJet Printer
Fuel gauge always full
  • Check the floater in the tank may be you need to replace it with a new one.
I’m happy to assist further over the phone at https://www.6ya.com/expert/ramy_d9e7ebea3891f482
Jul 25, 2009 | 2001 Ford Expedition
Ricoh Aficio MP C1500SP - functional error SC202
call ricoh serviceman he/she can fix it.
Defective tank full sensor
• Tank full lever bent or broken
• Incorrect ink suction
1. Check the harness of the tank full sensor.
2. Replace the GJ engine.
3. Replace the maintenance unit.
• The position of the tank full lever
does not stay at the tank full position
after ink initialization or air releasing.
• The position of the tank full lever is
not detected at ink suction.
Aug 19, 2007 | Ricoh Aficio 1515 All-In-One Laser Printer
Computers & Internet Logo
51 people viewed this question
Ekse
Marvin
Marvin
