Question about Samsung HLN4365W 43" Rear Projection HDTV-Ready Television
I have HLN4365W. When I turn it on, the screen shows lines and the picture is not clear. However, after 30 minutes or so, the picture becomes clear. What might be the issue with the first 30 minutes.
  • 1 more comment
  • Anonymous Nov 22, 2010
    These are light grey lines running across the screen. The lines flicker for 30 minutes or so before disappearing altogether.
    OK. Why does the screen work fine after 30 minutes if the capacitors are faulty?
    What kind of DMD board and where do I get this DMD board? Can I replace them myself...I mean what kind of expertise is needed to replace a DMD board on such a TV?
    Component level repair means replacing the faulty capacitors? Is that right? Do I have to buy these capacitors? Would appreciate if you could send me a link to buy these capacitors?
    As for soldering, I have seen others do it, should not be so hard to do.
eagle338
  • 4,889 Answers
What do the lines look like? Are they colored lines or just plain white lines?
Posted on Nov 21, 2010
  • 3 more comments
  • eagle338
    eagle338 Nov 22, 2010
    You will need to replace the faulty capacitors on the DMD board.Since these are not the the usual electrolytic caps that bulge at the top you are gonna have to test them with a multimeter with capacitance measurements and replace as necessary. Otherwise you can simply replace the DMD board.
  • eagle338
    Good question regarding the capacitors. You see when these cpacitors are malfunctioning their rapid charge discharge cycle is disrupted and it takes longer than usual to reach their optimum capacitance value. That is the reason the lines disappear after a while. DMD means Digital Micro Mirroring device. It is board that looks like this. And yes you can replace it yourself if you have the service manual. I will see if I have one in my collection. I will also look for the part and get you the link so that you can buy it online
  • eagle338
    Woah! It costs around 500$. I would we try a component level repair if you know how to solder?
  • eagle338
    Yes its not that hard. But you should practice it on something else first. The values of the capacitors should be inscribed on them like 100uF 200V. If you can get me these values, I can tell you where to find them. Oh. And you might want the disassembly instructions to get to it. So I am uploading the service manual right now and will get you the link as soon as its done.
  • eagle338
    Here's the service manual. Read the disassembly section of the optical block unit. If you get stuck somewhere then let me know and I will help you out
    http://www.mediafire.com/?at6qmxqzrx23d7...
I have a 37" JVC LCD TV Model # T370HW02 and the left half of the picture if filled with vertical colored lines for approximately 30 minutes after the set is turned on then the picture clears up and s
The problem with your TV is the screen tabs this is where the electronics bond to the screen a technician may be able to fix it with compression pads otherwise it a new screen
Apr 11, 2017 | JVC Jlc37bc3000 37 Lcd Tv 1080p
My Toshiba 46XV540U LCD TV. Has ghost image plus many white vertical and horizontal line when it is turned on. These lines and the ghost image stay for 20 to 30 minutes and than the picture becomes clear....
Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish board that call T-CON board to do a replacement.This T-CON board sit in the middle at the bottom of the tv LCD screen panel.This T-CON board control all the picture pixels going throught to the tv LCD screen panel.
Jun 11, 2011 | Toshiba 46XV540U 46 in. LCD HDTV
My Toshiba 50H82 television takes about 30 minutes to clear up and during that process, it shakes.It becomes clear but still has wavy lines at the top of the screen which is about 6 inches.
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 10, 2010 | Toshiba 50H82 50" Rear Projection...
KV36XBR400 fragmented picture horizontal overlapping lines
this will continue to degrade, almost any failure that can be affected or temporarily cleared up by hitting the set is caused by bad solder joints.
A good shop should be able to find and fix the bad solder connections for probably a little under $100
if you bring it to them and pick it up.
Feb 10, 2009 | Sony KV-36XBR400 36" TV
Plasma "warm up" is now up to 30 minutes and climbing
put a towel across the top of the tv so it can heat up faster and you will get your picture. be carefull!!
Jan 26, 2009 | Televison & Video
Toshiba 30" CF0C50
You have a bad capacitor in your vertical area.
Dec 29, 2007 | Toshiba 27A34 27" TV
Flickering/pixelating screen on LTV-27w6 HD after 30 minutes.
Sound like dry goint on Power Supply bord. I had the same problem and resolder most of the parts of the power supply and TV was ok.
Dec 22, 2007 | Westinghouse LTV-27w6 27 in. LCD HDTV
Picture problem
try to put away any electric device which is near your tv set
Nov 25, 2007 | Samsung HLN4365W 43" Rear Projection...
Toshiba 36A40 36" TV / Chassis No: TAC 0011
Bad capacitor in vertical circuit + possible vertical output IC
damage.If you can identify part locations and solder.....?
May 24, 2007 | Toshiba 36A40 36" TV
Picture is blurry
it sounds like the focus block or flyback is bad.sometimes you can put nail polish on the adjustments controls to make it stay.usually they are marked from the factory with white marks check and see if they are aligned.but be sure somebody with tech-skills help you.the flyback usually has a screen & focus control.(the big red wire to the tubes or block)
Oct 06, 2006 | Zenith Z46Z83D 46" Rear Projection...
Samsung HLN4365W 43" Rear Projection HDTV-Ready Television Logo
83 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Demonic-2011
Demonic-2011
