Question about Health & Beauty
FREERIDER ASCOT 4 Had flat batteries which now have been replaced but still no power to the motors. is there any damage that can be caused to the electronics by the batteries going flat over a period of time?
Posted by tony_donald on
sonny tee
    Problem Solver:
  • 18 Answers
No or every unlikely.
electrics may be damaged from overvoltage or overloading the motor while it is stalled (steep hill) but not from batteries going flat.
Posted on Nov 22, 2010
Hi, my wife's freerider Mayfair mobility scooter keeps going slow, have turned speed control down but still seems to loose power, doesn't stop just slows then reverts back to the speed set.
there are four possible reasons why a mobility scooter loose power including the user weight (vs. max weight of a mobility scooter), the weather condition, the riding routine and the battery age. You can check those factors to figure out the root cause. http://trustedmobilityscooters.com/reasons-mobility-scooters-loose-power
May 06, 2017 | Cars & Trucks
My scooter slows down then goes back up again
The problem you have got is the throttle pot is faulty. Get this replaced and it will be fine
Jun 19, 2015 | Pride Mobility Products Celebrity X...
How many miles can I get from a fully charged Freerider Ascot 4 mobility scooter? My scooter seems to run out of charge after a few miles.
11 miles on full charged new batteries, this is approximately as condition change max distance, like you weight, if you are going uphill, how even the ground is etc. if you need more you could get a spare battery pack for it, and swap them over when needed. but remember to keep them charged even when not in use once a week is the best way to keep them in good shape.
Sep 09, 2013 | Health & Beauty
Freerider Ascot scooter will not work - battery fully charged - green light is flashing
Possible fault in the drive selector switch/ circuit or the motor. You can check the motor, test using a DC line to confirm. If so the selector drive is faulty. check the continuity and the DC drive feed to the motor. It is possible that the circuit is not working and so the board needs a check/replacement.
Jul 11, 2011 | Rider Toys
Freerider Ascot Electric Mobility Scooter (4 wheel) Battery charges and holds current - horn works and shows green on power dial Scooter hardly moves underload - the engaged lever is set correctly. I...
I would suspect the brake is not releasing correctly and dragging on the motor housing. Try driving the scooter a short distance and feel the motor case at the rear near the brake assembly if it is very warm or hot the the brake is sticking and will have to be replaced. Hope this helps
Jun 03, 2011 | Health & Beauty
Battery full on Ascot Mobility scooter but wont start
mcdevito75 here, Double chek the connection at the battery and motor.
Jun 22, 2010 | Electric Strider Maxi 4 Wheel Mobility...
Ascot VT500 VT - no power not battery
Hi and welcome to FixYa,
Was the main 30 amp fuse checked/replaced? The main fuse would on the starter relay. To locate the starter relay, follow the cable from the battery's + terminal.
Good luck and thank you for asking FixYa.
Mar 29, 2010 | 1983 Honda vt 500 ft ascot
Freerider mayfair, no life at all in scooter
Look carefully , you will find a fuse , gently pull the wires around the seat stem , sometimes it can get buried under the power leads from the battery.
Regards
GeWiz
Sep 30, 2009 | Health & Beauty
Health & Beauty Logo
171 people viewed this question
Top Health & Beauty Experts
ray gallant
Bill Boyd
Andrew Taylor
Andrew Taylor
Are you a Health and Beauty Expert? Answer questions, earn points and help others
