Vizio M3D420SR No Power No Lights
If you have checked and confirmed that the voltage at the PS_ON pin does not change when hitting the power button, it is possible that the main board (756TXBCB2K013) is the faulty component. The main board is responsible for sending the signal to turn on the power supply board (ADTVA2419XYG).
You may want to try disconnecting the main board from the power supply board and then pressing the power button. If the voltage at the PS_ON pin changes, then it confirms that the main board is faulty. If there is still no change in voltage, then it is possible that the power supply board is faulty.
Alternatively, you can also try checking the capacitors on both boards for any signs of bulging or leaking, as faulty capacitors can sometimes cause issues with power supply.
