Hello
If you see the picture in yellow colour, means that there is no blue colour output from the video drive section in your tv, Yello is the mixtrure colour of red and green. Green is actualy there. blue colour is absent.
To detect this fault, you must open your tv. Just look in to the video output section, can be located at the picture tube base card, which is plughed into it diretly. See for any loose soldering points there. Check whether transisotors are used for red, green and blue output stages, or an Ic or three seperate Ics are used for this purpose. Anyway, blue catode of your picture tube pin gets a hig voltage, and so the blue emission is absent. You just check the voltages at red,gree and blue catodes, at the respective picture tube pins, which can be taken at picture tube base card. All of these three pin voltages must be somewhat equal to each other. In your case, no voltage at blue cathode will be higher that the other two. Check for the reason. It may be due to an open video output transistor [blue], or an Ic, of one Ic if used for the three colour outputs. Check and replace the same, will rectify your problem. Ok
If you have andy difficulty, get it to me through Fixya. Ok
Gopakumar, India.
