Is your TV older than the remote's programming date by at least 6 months? The code you need for a newer TV may not be included in the remote.
If the TV is compatible with the remote codes, then try the Apex codes: 1037, 1043, 1050, 1071 . You can also try the manual coding. Turn on the TV (turn off other devices that may respond to the IR signal). Then press and hold the TV button on the remote (the illuminated TV will turn on). While holding the TV button, press and hold the On/Off button. The illuminated TV will turn off. Continue to hold both buttons for at least three seconds, until all of the component names light up. Then release both buttons (the TV will remain illuminated). Press the On/Off key repeatedly (up to 200 times) until the TV turns off. Press Stop to save the code. Try to use the remote to control another function on the TV. Repeat the manual search if the code doesn't control the TV completely.
If the TV light blinks 4 times and goes off, you have searched through all of the codes. The remote exits the manual search at that point.
I hope this helps.
