Cnet CWR-854 Router Logo
Posted on Nov 21, 2010
Ok. i have just bought a ultra speed wireless N router..... i plug everything in and it is supposed to have a window pop up and it doesnt.... i tried http://192.168.1.254 and it wont go to that page.... what should i do or try now?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 22, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
7188
Points
8
I have that router... I HATE IT!!!
What I did was... #1. Unplug both the router and modem for about a minute. #2. Plug them in again and when they are both fully booted up... #3. Press and hold in the WPS button on the back or the router for approximately 5 seconds. #4. You should see a wireless network become available called MyWLAN #5. Just go through the router setup.
Hope this helps a little
Anonymous
Level 1:
New Friend:
  • Posted on Jul 02, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
7188
Points
2 Related Answers
eastpole
Tai Viinikka
  • 22 Answers
  • Posted on Jan 10, 2011
SOURCE: set up router/modem as instructed
Problem can't be solved as described, a fixer would need more details.
What kind of modem/router is it?
What instructions are you working from so far (you say, "as instructed" so I take it you're looking at a Quick Start Guide of some sort?)
How are you connected to it?
What http address are you going to (E.g. some routers use 192.168.1.1, others 192.168.1.254 or various alternatives)
What happens when you enter that address on a browser?
Have you set your computer's address to a nearby address so it can talk to the route?
If I had one guess with not enough information, I'd say you need to set your PC to an address one different from the target you're going to.
( http://compnetworking.about.com/od/workingwithipaddresses/g/192-168-1-254-d.htm )
Tom Marvolo
Rakesh Warrier
  • 708 Answers
  • Posted on Jan 10, 2010
SOURCE: cant get into the settings of my belkin router http 192 168 2 1
Step 1 : Check the IP Address of the Computer
Step 2 : If it is in the Range of the Router ( 192.168.2.x)
Step 3 : Try typing 192.168.2.1 on the address bar of internet explorer
Step 4 : If not working Hard reset the router by inserting a paper clip into the reset hole on the back of the router
Step 5 : If the IP Address is any public address or 169.254.x.x then also do step 4
Everything was finewith wireless until we pluggd ethernet cord into back of siemens for xbox 360 now computer (wireess) doesnt work upstairs help
check what cable you plugged into the xbox...and be sure is not the main internet cord that it supposed to be in the wlan port of the router ...and get a cable from one of the router's LAN port into the xbox..and leave the main one into the wlan ..this way you will have wireless ...if the configuration on cables is ok ...get into the settings of the router from the admin computer the settings were made in the first place ....and see whats wrong with the wireless settings ..they may be disabled by mistake ..or another odd reason ...and enable the wireless transmitting again ..
I just bought a belkin wireless modem router (F7D1401). I have installed the belkin router monitor software in my laptop which running on Window XP. After installing the software, there is no window pop up...
Hello
It shows that the software does not installed properly, or you might select diffrent OS during installation, re-installation with proper inputs is recommended,
Good luck, do rate the solution if got help
I am trying to connect a wrt150n wireless linksys router to my dsl. I am using a desktop windows 7 and laptop windows vista. Please help, I have tried everything but it just does not want to work.
unplug everything, including ethernet cables. then work in this exact order.
if you get a wireless signal and no internet, plug a computer in into the router in one of the available ports and check for internet. If no internet, unplug everything and test the modem without the router. If internet available without the router, then follow these instructions
  1. plug phone line into modem
  2. plug power into modem
  3. wait for all lights to become steady
  4. plug ethernet cable into modem
  5. plug other end of same cable into port labled "internet"
  6. wait for lights to become constant on both router and modem
  7. check your wireless device for wireless service.
if you dont get a wireless signal at all, plug your device into the rear of the router and type 192.168.1.1 in the adress bar
the password and username are both "admin" or simply leave the password blank if that doesn't work
navigate to the wireless option and turn on the wireless transmiter.
GOOD LUCK AND PLS RATE THIS POST!!!!!!
I just bought an acer laptop with windows 7 and cant figure out how to set it up to use it through wireless
Bring up the control panel, in the top right choose small icons so you can everything in the control panel. Choose "Network and Sharing Center". At the bottom section, choose "Connect to a network". A list will pop up of the available wireless networks to connect to. Just make sure your wireless radio is on. If you see the network you want to connect to and your radio is on but you can not seem to connect to the network, the first thing to do is remove the power plug from the router for 1 minute, then plug the router back in, this will reset the IP address for all devices. Once the activity lights on the router get steady, try to connect again using the before mention procedure.
Internet problems
try resetting your modem, not the router. Unplug it, wait a bit and plug it back in. the modem needs to see the routers ip address so it allows connectivity. Right now the modem has your computers ip address and doesn't see the router, until you reset it. try it, it should work.
1helpful
2answers
I have forgotten my password and need to connect a new computer to my router-the router is a belking plus mimo and I have a linksys wireless g speed booster -what do I do to fix this? Many thanks
Reset the both routers in order to go to the factory default setting.
BELKIN (192.168.2.1) normally has no user name or password. So just hit enter.
Linksys (192.168.1.1)
User Name: admin
Pass Word: admin
You can always change the user name and password
Good Luck!
Windows xp sp2 doesn't recognize and software will not let me connect to router
First of all you have a wireless "N" adaptor running on a router set for 802.11g. You need to have the same router as the adaptor, "N".
Slow Speed on Wireless Connection
As you said , try upgrading your routers firmware, but the better fix would be for a n router with a n card you will have a proper synchronisation and good speed.. or else the speed will vary, for a g router and n card..
Get booted off
Ok. i have the exact same problem, but i use linksys. I have has geeksquad and they dont know. I have only one option i havent tried. try to just hook up the modem to your router only. Buy a wireless adapter for your home computer. If it doesnt work, return it for a refund. I feel for you guys because i have been going through hell and it drives me crazy that even geeksquad doesnt know. (By the way dont buy that garbage when the people say you need a new router, because they just want more money.)
Set up
OK. First unhook everything. Connect and power on your cable/DSL modem, next plug in the ethernet cable from the modem into the router, there is a specific jack for this, you can then power on the router. Next attach your desktop and any other computers you wish to use with wires to the router and power them on. Your wireless should work by default, but if it doesnt type 192.168.0.0 and type the default password, generally admin, and change the settings in the wireless security menu to set up your wireless laptop.
Top Cnet Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Cnet Computer and Internet Expert? Answer questions, earn points and help others
