Probably not. The compressors are very sturdy and long lasting. The compressor is controlled by a start relay, and is protected by a thermal overload. It sounds like your start relay is bad, which would explain the buzzing sound. It takes a certain amount of time to cool down, and then tries to start again. The start capacitor and start relay should be replaced.
You have a defrost timer behind the front kick plate turn
it clockwise slowly until compressor and fans stop. Once this happens the timer
should remain off for 30 minutes and the defrost heater should come on during
the first 15 minutes. If after 30 minutes the defrost timer part=> 215846602 Defrost Timer Assembly
should come out of defrost and the compressor and fans should restart, if not
advance the timer clockwise until they start and replace timer. Try that first
and tell me what your results are. If that is not the problem then we can
narrow this down to the defrost heater=> 218657301 Defrost Heater
or 5303917954 Defrost Thermostat How to test the defrost heater is
found on same page as the defrost heater. If you have any questions I will be
here to help you, Thanks Sea
Breeze
