Question about Sharp Aquos LC-45GD6U 45 in. LCD HDTV
Suddenly, my LC-45GD6U picture went black and now there is no picture but the blue power light is still on. I cannot change channels, change the input, change volume, etc. Basically the TV does not work with the remote or the buttons on the top of the machine. I have unplugged the unit and plugged it back in - still have the same problems. In fact, I cannot even turn off the TV!
  • 1 more comment
  • Anonymous Nov 21, 2010
    How do I replace it myself? also, how much would this cost to do it myself vs. a repair tech?
  • Anonymous Mar 30, 2014
    when i changed the channel my tv picture went from no picture to dark and light blue verticle stripe
eagle338
  • 4,889 Answers
Look like a classic case of Main SSB failure. Do you have sound? If not then it is confirmed that the microprocessor on the SSB has failed. YOu are gonna have to replace the board to fix it. Let me know if you want to do it yourself
Posted on Nov 21, 2010
  • eagle338
    eagle338 Nov 21, 2010
    It is easy. You will find the board under a metal plate at the center of the set. Remove it and get me the part number off it and I will find you a replacement. Replacement is very simple. You should just unplug the connectors from the older board, re-plug them on the new one and screw it to the chassis. Cost if you replace about 150$. If the tech replaces it 400-500$
I was watching my tv and it suddenly went totally black. I can hear it ,change channels and use the column but still no picture. What problem would this be?
picture board failure
could be from over voltage supply from the power unit or other related component
get a proper diagnosis done first to find the cause of the failure
Jul 02, 2018 | Televison & Video
Screen went black while watching, now ony have sound
Look at the venting grills, you should see whit lights inside the set. If not, the backlight inverter board may have gone out or the power supply supplying the power to the inverter board may have gone out. Those are the two places to look first. It may have bad capacitors in the power supply.
http://en.wikipedia.org/wiki/Capacitor_plague
Nov 06, 2009 | Sharp Aquos LC-20B4U-S 20 in. LCD EDTV
Red power light continuously blinking. no picture no sound.
It could be the lamp went out and needs replacement. The Toshiba website states when this happens to unplug the televison for 10 minutes then plug back in. If that does not work then try another power outlet. If that does not work then call for service
Sep 12, 2009 | Toshiba 57H81 57" Rear Projection...
The audio on my LC-45GD6U goes in and out (mostly
if its fine on other channels i would not suspect the tv
Aug 26, 2009 | Sharp Aquos LC-45GD6U 45 in. LCD HDTV
Plasma Hyundai 42'' TV ,NO SOUND OR PICTURE
most times then not it's the capacitors on your power board that blew there for not supplying the tv with enough power if you open it up and check the capacitors it should be leaking some kind of liquid or the tops have bubbled up. its an easy fix cost>>2 dollars each
May 21, 2009 | Televison & Video
Sharp Aquos wont turn on
this is either a power problem or the screen needs re-gasing
Jan 17, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I cannot change the channels on my direct TV receiver when tv is
Have you tried a factory reset on the TV.Also try unplugging the tv wait about 20 seconds and then plug it back in.Last check the trouble shooting in the tv manual
Feb 08, 2018 | Sharp Aquos LC-45GD6U 45 in. LCD HDTV
Sharp LCD LC-46D64U
Try resetting the TV. Here's how to do it - Unplug the TV's power cable. Keep the Channel Down and Volume Up buttons on the TV pressed and plug the power cable back into the outlet. You will hear a click when you plug it back in if the reset is successful. Hopefully this should restore your video and audio.
Dec 25, 2007 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Open Questions:
Sharp Aquos LC-45GD6U 45 in. LCD HDTV Logo
Top Sharp Televison & Video Experts
Demonic-2011
Demonic-2011
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
