Question about Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU)
You gotta flip the nat/LP nut on the gas valve itself. All the burner orifices need to be changed or cranked down if they have spuds and the air shutters opened up. Then ya might have to tweak the system.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Nov 21, 2010
To convert from N.G. to L.P. you will need to change pilot and all burner orifices. And change gas valve pressure regulator. Gas valve must be convertable to accomplish this. Do not try to use N.G. orifices fof L.P. as L.P. runs at amuch higher pressure than natural gas and holes in orifices are much smaller. If worst comes to worst you can purchase convertable valve and the right orifices. Or change orifices and install L.P. gas valve. I hope this helps you. Thanks.
You will will have to change the reg as ng burns at 4inches and lpg burns at 14 inches and pilot orffice if fitted
Nov 15, 2014 | Coleman Gas Fired Mobile Home Furnace,...
Nov 10, 2013 | Coleman Home Electric Furnace Eb15b/Eb15d
Mar 26, 2017 | Carrier Grilling
Feb 05, 2013 | Heating & Cooling
Sep 14, 2011 | Barbeques Galore Capt'n Cook 3-Burner...
Sep 12, 2011 | Weber Summit S-670 Gas Grill
Mar 21, 2011 | Imperial IFS40 Deep Fryer
Nov 22, 2010 | Heating & Cooling
Oct 26, 2010 | Heating & Cooling
Jan 18, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
May 15, 2014 | Coleman Propane Forced Air Heater...
660 people viewed this question
