Question about Just Wireless Bluetooth Headset Wireless Headset
I just bought a Just Wireless BT-15K. When i plug it into the charger my first indication that something is wrong with is the Red light will not stay solid it dims and blinks every 10 to 15 seconds i left it plugged in for three hours. when i unplugged it to pair it won't turn on. is there a solution or do i have to take it back.
Posted by Christian Shinsky on
  • Christian Shinsky Nov 21, 2010
    ok i finally got it to charge right but now it's been charging for 14 hours and the light has not turned off and when i unplug it it will not turn on... am i doing something wrong
Don Eagan
    Master:
  • 714 Answers
Take it back. Something has a short in it. Do not leave it plugged into the charger or you could have a fire.
Posted on Nov 14, 2017
1 Related Answer
sonicboomele
sonic boom electronics
  • 1557 Answers
SOURCE: I just bought the BT-15K.
it seems to be turned on try turning it of and then charge
Posted on Feb 15, 2011
I just bought th hv 800 bluetooth headset, when i
might indicate it is fully charged already .
Sep 23, 2014 | Radio Communications
Plantronics audio 995H wireless headset not charging when plugged into computer. It does not show a red light for charging. When turned on it stays blue for several seconds then flickers red for 2 or
38cafd7a-6060-4717-bc4f-b4db91cc266a.jpgI recently fixed my 955 headphones... it's probably not going to be attempted by most folks, but it saved a great set of headphones from being tossed and replaced.
Basically you need to remove the right side padding and take out the 3 screws. This gets you access to the battery. The battery is a standard 3.6V lithium battery. Pretty much the same that is in most cell phones and many small toys. You can simply replace the battery with something like:
http://dx.com/s/3.7v+li
Or... here's what I did... add a lithium USB charger to the battery.
http://dx.com/s/li+arduino
Now, if the battery dies I can plug it into USB and the phone will work while it charges.
Nov 12, 2013 | Plantronics .Audio 995 Digital Wireless...
Cellular Innovations HFBLU-FP1 T2 FP1 wont charge
bluetooth - charging mashine problem bring it to recheck the charger
Apr 15, 2012 | Cellular Innovations HFBLU-CX1 Wireless...
Kenko
read the owners hand book
normally the lights stay red until the battery is charged then it goes green
if the power is cut or if you switch the point off with the charger still in it and do not remove the charged battery , the battery will discharge through the charger
Mar 27, 2017 | Kenko MC-4 DG for Nikon AF 2x (MC4AFNDG)...
WON"T WORK
sounds like a dead battery. Plug the origional charger into it and the front led (below the flash) should flash red. If the red led in the back of the camera flashes or stays lit, then you have the wrong charger plugged in. (the camera won't power up if the back red/green led is on when plugged in)
May 08, 2008 | Jazz DV-179 Digital Camera
BT330 Headset, not charging
I just purchased one and im having the same issue. How can I get it to work? Am I doing something wrong?
Sep 17, 2007 | LG HBM-300 for VX9800 Wireless Headset
Just Wireless Bluetooth Headset Wireless Headset Logo
1,175 people viewed this question
Top Just Wireless Radio Communications Experts
Rocketmanusa
Level 1 Expert
Anthony Ward
Anthony Ward
robert
Are you a Just Wireless Radio Communication Expert? Answer questions, earn points and help others
