Slide the cover all the way down until it stops. Then using gentle pressure push the low half of the cover down to lever the top edge over the two small lugs.
To put the cover back on after changing the batteries, apply the same technique to slide the cover back over the lugs.
Thank you so much!!
Thank you so much!
Thanks heaps, was about to pull the whole thing to peices. Easy on your advise.
You're welcome.
thought i would have to buy another remote. now i dont!!!! thankyou!!!!!
Many thanks. I too thought I'd have to purchase a new remove. You've made my Canberra winter nights much more pleasant as I'll now be able to boost the heat level !!
SOURCE: Changing the battter of the remote control
Slide the cover down as far as it will go. Now using your fingernail, gently lever the cover off from the base, it will click out without much force. This is a stupid and confusing design and should be changed.
SOURCE: How do I change the battery in the remote control
slide the cover of the remote up higher. It is hiding the batteries.
