What are the wiring color codes for car stero of 1997 nissan altima i hooked up all my speaker wires. I have a redback, yellowblue,redblue and a blue. For the stero im trying to hook up i have a blue for antenna a red for ignition and a yellow for battery?
1997 Chevrolet Lumina Car Stereo Radio Wiring Diagram Radio Constant 12V+ Wire: Orange Radio Ignition Switched 12V+ Wire: Yellow Radio Ground Wire: Black/White Radio Illumination Wire: Gray/Black Radio Dimmer Wire: Brown/White Left Front Speaker Wire (+): Tan Left Front Speaker Wire (-): Gray Right Front Speaker Wire (+): Light Green Right Front Speaker Wire (-): Dark Green Left Rear Speaker Wire (+): Brown Left Rear Speaker Wire (-): Yellow Right Rear Speaker Wire (+): Dark Blue Right Rear Speaker Wire (-): Light Blue
1995-97 Nissan Maxima Stereo Wiring
Constant 12V+
Pink/Blue
Switched 12V+
Blue/Black
Ground
Vehicle Chassis
Illumination
Red/Blue
Dimmer
Red/Orange
Antenna Trigger
Black/Red
Antenna
Right Rear
Front Speakers
6 1/2" Doors
Left Front (+)
Blue/White
Left Front (-)
Blue/Yellow
Right Front (+)
Brown
Right Front (-)
Brown/White
Rear Speakers
6 1/2" Rear Deck
Left Rear (+)
Red
Left Rear (-)
Green
Right Rear (+)
Blue
Right Rear (-)
Pink
Nissan change their color codes on their harnesses all the time , a diagram won't be much use. What has happened is that Nissan has a wire that appears to be an earth in the stereo harness , but goes live when the headlights are turned on ( it is there for the factory stereo to dim the lights when the headlights are turned on.) Easiest way to connect stereo is to use a Multitester set on 20 volts to find Power , Accessory and earth wires, remembering to turn your lights on and off each time to check for the Nissan sneaky wire. ( You are lucky, I have seen whole looms go up in smoke because of that wire ) To isolate the individual speaker wires, solder a couple of wires to a AA battery and " flash " it across the pairs of suspected speaker wires while listening for a " Crackle " from the speakers, this is a handy way to figure out which wires go to each speaker without having to pull the doors apart to look. Happy Fixing Marshall
should be a red for hot black for ground yellow for memory and blue for amp remote. the rest of wires are speaker wires. match wires with car radio has a pair of wires for each speaker. like tan for positive tan with stripe on it is ground.
