You have to fill the tank with more than one carafe. Most of them are syphon/gravity fed machines meaning the cold water coming in forces the hot water out to brew the coffee. Hope this helps. WWW.MidstateBeverage.com
SOURCE: my bunn is too slow
Use the de-liming spring to clean the copper tube behind the spray head. Pour several pots of clear white vinegar through the unit to further remove lime and scale from the interior of your coffee maker. My Bunn is 24 years old, and the only replacement parts I've ever required are new carafes and the 4041 silicone washer repair kit.
SOURCE: BUNN BX-B Coffee Maker Leaking
is it the water container that leaking the best thing to do is open it maybe is a loose pipe or dry pipe connected to water container and if it the water container use 5 or 1minute epoxy cheers
SOURCE: Bunn Coffee Maker Leaks out the bottom
Contact Bunn and they will send you a free repair kit with good illustrated instructions.
SOURCE: bunn omatic model F20 doesn't stop dripping
Check out:
http://whles.com/General%20Mtx%20Knowledge%20%20Tony%20Roach/BunnOMatic%20F35%20F20%20F15%20x.pdf
This is the free full service manual F15, F20 & F35 complete with troubleshooting section at the rear. This section has easy, plain english steps to follow to solve this very problem (others, too).
SOURCE: Water supply for Bunn coffee maker
open the cover on the brewer- depending on your model, it could be the front or the back cover. look for a brew timer dial. turn this up slowly, running a brew each time to see if you now have a full pot
