Question about Price Pfister Home
The device the sprayes water from the shower head has broken. The shower head does not unscrew for the shower arm. The shower arm is attached behind the tiled wall. How do I remove the shower arm and attach a new arm and shower head ?
Posted by btsmoto on
Tim Whalen
  • 3,074 Answers
I would make an access panel on the back side of the shower, this way if I ever need to access the shower lines/fixture in the future I can do so, Hope this helped Tim, here is a website that may help:
http://www.ehow.com/how_6071986_install-price_pfister-shower.html
Posted on Nov 20, 2010
George Hels
  • 528 Answers
The shower arm should be screwed into an elbow inside the wall. Unscrew the shower arm by putting your pipe wrench on the arm and unscrewing in a counter clockwise direction ( lefty loosey, righty tighty ) . Measure the length of the arm going inside the wall and make sure your replacement has enough length to reach. Teflon tape the inside end ( the end going in the wall ) and wrap a rag around the new arm, then screw into the elbow going clock wise , stopping when it starts getting tight and with the bend facing downward. Install shower head.
Descale a showerhead
  1. What to do
    1. Unscrew the head of the shower from the hose. This may be quite stiff. ...
    2. If it is possible, unscrew the rose attachment from the shower head. ...
    3. Soak the parts in the descaling agent or white vinegar overnight. ...
    4. Reassemble the parts, checking that the rubber washer for the hose is in place.
Descaling shower head
Jul 21, 2015 | Water Water Heaters
Ok we'll I'm trying right now to unscrew my old ball end shower arm and cannot for the life of me get it to unscrew and can't understand why?? I'm not too sure how long it's been there but it won't even...
use multi grips and unscrew the shower arm from the wall and attach your new arm in its place
use use multi grips on the knurled section that holds the ball ( shower head ) on and fix your new shower head in its place finger tight
Jun 07, 2017 | Cars & Trucks
I have a delta in2ition shower head. The shower arm has a water outlet head that is screwed down onto it (the water outlet head is round like a ball and has a hole in the middle of it from which the water...
Take the gasket to your local hardware store and have them match it up.The answer is no, the gasket is not supposed to be split. It was probably tightened too much.
Jul 24, 2011 | Delta & Single Handle Shower Faucet
I've attached the shower head as tightly as I can but water backs up and sprays upward and outward with very little coming out as spray. Seems that a washer is needed but note came with my...
There should bea rubber gasket/washer that goes between threads on shower arm and inside of shower head. If this is a new shower head I would return it to place of purchace for exchange. If not you should be able to get the waher seperatly. If not you can get a cheap shower head and use the gasket from it. I also would recommend that you use several wraps of teflon pipe joint tape on shower arm and tighten snugly.I hop this helps you. Thank you a have a good year
Jan 02, 2011 | Water Pik Shower Head
I have a Mira Sport shower 12 mounths old. Water has started to leak out of the unit and runs down the outside of the outlet pipe.
if the water is leaking out the head, unscrew the head and put thread tape on arm of shower were the male thread is and make it tight again, if the arm ... unscrew the arm and put thread tape on the male thread of the arm and screw into feamale thred that is an the wall. if not 1 of those are the problem , clarifi and all give u a solusion
Jul 08, 2010 | Home
Delta Victorian 5-Spray Hand Shower has no
hello
of corse ... sir want to get thread tape befor trying to fix the head .
unscrew the head of the shower not the arm.
after unscrewing the head ,look at the back were the thred is, there will be a siff. thust clean out the sif, put thread tape on the head again and bobs your uncel hehe. if that dosent fix it let me know .
Jul 08, 2010 | Delta & Victorian 5 Spray Showerhead
The Grohe Movario shower head how do unscrew it to clean the head
On the face of the shower head where the water sprays out of ,their should be a threaded nut to unscrew This is called the aerator.This is the part wher the filter screen is .Once you clean this part you should be up and running.
Jan 25, 2009 | Grohe 28.444.AV0 Movario 5 Spray Hand...
I'm trying to replace my shower head and am unable to remove the old one from the shower arm diverter, any help would be appreciated
use a crescent wrench on the shower head. If the head alone won't budge, the entire head plus arm will unscrew. Then just pick up a new arm and some teflon tape and reattach both. good luck
Jan 18, 2009 | American Standard 1/2in NPT Shower Arm...
Leak where Grohe shower head attached to the threaded pipe
Hello, Many shower heads have similar problems. (Very frustrating as you now know) The problem is the threads at the end of the (cheap plastic) shower neck are not flat. They are tapered (has an edge) - so it does not seat flush with the base of the shower head. Actually cuts around the rubber washer causing a leak.
What to do about it?
File the end of the neck some to create a flat surface. However, go slow. Be sure you can still screw on the shower head. Add a flat rubber washer in the shower head and plumbers tape on neck threads too.
Or Purchase a new shower neck that has a better design. The neck should unscrew from the front. Check and make sure you have an access behind the shower just in case you need to access the plumbing.
I replace the shower neck myself if there is an access.
Rob
Jan 17, 2009 | Grohe 28.275.AV0 Relexa Plus Top 4 Spray...
Home Logo
328 people viewed this question
Top Price Pfister Home Experts
Bill Johnson
Mike
Bruce Robin
Are you a Price Pfister Home Expert? Answer questions, earn points and help others
