The number you need is either on the glass bulb or on the metal base of the bulb Look on the access cover to see if the replacement number is there, too.
Hello Are you need its service manual? Only service manual will have all part numbers and schematic diagrams. If you are in need of it, inform me please.
Your model doesnt have a bulb since its a rear projection TV . It has three picture tubes, However loss of video with audio still working is usually caused by a vertical output failure.
Take the old bulb out, there will be a number on the bulb, you can take that number or whole bulb to any parts store to have it replaced. ' If there is no bulb, again a parts store can look up the vehicle and get the correct bulb replacement
I have the book for the Sunbeam Model 7622. It lists a toll-free number as 800-394-2326 with the price for the replacement bulb as $2.95. It may be higher now as the 7622 was purchased in 1997
just the bulb.. write down the model number of the unit and they will give you the same bulb that you need, just give them the model number.
If you are going to install the bulb just remember DO NOT HOLD directly the bulb, use any clothe or gloves, because even a fingerprint can busted the bulb even thou it's not yet use
hi from uk the number plate lights x2 are on same fuse as side+tail lights so if n/plate is not lit ?more likely bulbs have blown ? to access remove the panel from boot lid (clips+screws) then you will see rear of n/plate lights the bulb holders twist anti clock slightly and pull out replace bulbs with same type 5watt check all work b4 refitting panel
looked up the bulb part is no longer available, but it looked like a regular appliance light bulb, remove the old one no diffrent then any appliance bulb you can buy in the supermarket if need be
