I have a samsung HT DS610 and when i turn it on, i get a protection message and it shuts off.I have it disconnected from everything and i keep getting the same messaage.
the main reason home theater goes into protection is speaker fault disconnect all speakers and power allow to sit for 20 mins then plug it in see if the protect is gone if so then connect speakers one by one untill you find the faulty speaker
Some components in your amp board short,
if you can replace yourself search the board model no.
and buy it , much cheaper than send the unit for repair
I have this problem with a Samsung HT-TZ325 and I disconnected all the speakers and isolated the problem to rear right speaker I now disconnect this plug prior to switching on the system . I then reconnect the speaker (rear right)
Protect mode will kicking whenever a fault is detected.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring. Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault. Internal
fault is the natural cause for protect mode. If all the above did not
work, then the problem is a blown component or an internal fault. In
this case the unit must be taken apart , tested and repaired by an
experienced person. If the unit is less than one year old, or if you
want to get service, call Sony at the phone number listed on the
product documentation.
I found this online. Don't know if it helps you guys or not?
Samsung HT-DS610
1. Remove any discs from the tray 2. Flash the RAM (disconnect from the mains for 30 seconds) 3. Plug it back in, switch on from the remote 4. Wait for "No disc" message 5. Press Enter. 6. Press 8,4,2,6,9 slowly. 7. Press Enter. You may need to repeat steps 4 through 6 before the try is open.
