Question about Bialetti Moka Express 6-Cup Coffee Maker
Somehow the top got screwed on too tightly and we can't unscrew it! I tried soaking it in water in the sink. Any ideas?
Posted by edin279 on
Pennywhistler
    Champion:
    New Friend:
  • 231 Answers
Heat it up a LITTLE BIT. Perhaps run it under hot water.
Posted on Jan 01, 2015
How to remove and replace dishwasher?
Turn off the circuit breaker for the dishwasher power and shutoff the hot water supply (usually located under the sink). Next take off the lower bottom front cover to access the electrical connection and water supply line. Remove the cover to the electrical connection and disconnect the wiring. Pull the supply wire out of the connection box. Next loosen the connection for the water supply line. Have a towel handy to soak up the residual in the water line. Disconnect the drain hose from under the sink. It is either connected to the garbage or to a tee above the sink drain trap. Loosen the clamp and remove the drain hose. Again you'll need that towel to soak up the water from the drain hose.
Most dish washer are attached to the bottom of the counter top above the top of the d/w door with screws. Remove these screws. You may also need to loosen the leveling feet located on the bottom of the d/w at the front in order to pull it out.
Now you can remove the D/W from under the counter top.
Be sure to keep the drain hose on top of the D/W while pulling it out to keep the residual water from draining onto the floor.
Be sure to secure the electric supply wire with wire connectors after the D/W is removed for safety. Also cover the drain connection at the sink or disposal with duct tape to prevent sink water draining into the bottom of the sink cabinet.
Nov 19, 2017 • Dishwashers
1helpful
How do I change the washer on faucet
1. turn off water under sink 1st both of them
2.remove the handle screw on top or allen screw under bottom of handle pry off
3.crescent wrench unscrew valve remove
4.on bottom of stem unscrew remove washer{replace the "O" ring on the stem while out}
5. put back and turn on water check for leaks,
Hope this helps let me know Mike
I cannot unscrew the top of the Mukka Express machine from the bottom!
If the bottom is screwed too tight on the top, you could try to warm the with hot water and cool the bottom with cold. This could help to expand the top and make it easier to unscrew.
3helpful
Have Kohler diverter, GP 75878 but no instructions as to how it should be installed. Is it under sink where sprayer hose is attached?
Shut off water supply Under Sink: · Unscrew brass connector for spayer hose · Disconnect single water line to faucet bysqweezing lever on connector and Gently pulloff. · Loosen two screws on faucet base washers thenunscrew the washers on thebrass faucet shaft ( NOTE: Have someone hold the fauct so it does Not accidentlyfall in sink when the support washers are removed) · Take faucet out of sink · Unscrew brass collar at base and remove · Remove Set Screw on lower body of faucet · Pull out Brass Mechanism from faucet · The Diverter is located in the Brass mechanism · Remove the Washer · Pull off the small top valve in center of theDiverter, if still there · Using a large wood screw that fits/screw intothe exposed hole In the center of The plasticdiverter, screw it in and pull out the remaing part of the old diverter · Flush out Faucet to remove any remaining debrie · Replace with new diverter and replace washer · Grease all areas that where greased when mechanismwas removed Remove & clean the faucet Airrater and replace only afterEVERYTHING has been Completed soyou can flush the faucet out again into the sink, then replace.
3helpful
2answers
Can I remove the screen filter in the kitchen faucet and clean it? A112.18.1M 2.26pm 8.33L 7MIN. I don't want to try to unscrew the part and find out I shouldn't have. How should I unscrew it?
Yes, the aerator (where the water comes out) can be unscrewed and removed from the faucet. I remove these and clean them out on a regular basis. If the aerator won't unscrew by hand, place a washcloth over the aerator (to prevent scratching) and carefully turn it with a pair of pliers. (Screw direction to loosen: Looking down on faucet, with pliers to the right-hand side, pull them toward you.) Make sure the rubber washer is properly placed in the top of the aerator after you have cleaned it out and you go to screw it back on. You normally don't need pliers to put it back on, as these are meant to be screwed on hand-tight. There might be several little parts inside the aerator to take apart and clean out, so be very careful to put these parts back together the same way they came apart. I find a toothpick is often useful to clean these out, as well as a cup of water to rinse them in.
How to change the water filter?
Meridith just remember this old adage whenever changing filters or unscrewing anything. It's always lefty loosey, righty tight.
RJ
1helpful
Water leaking under floor when dishwasher runs
check the water to the unit it is locate under the door open the panel 2 -4 screw take flash light turn the unit on and see where the water come from ... it might be also from under your sink.
Jan 01, 2010 • Dishwashers
Water is getting in to passenger footwell and soaking acrpet
You may have a bad door seal, check the rubber gaskit strip around your door frame and make sure it's not ripped or simply out of place. Also make sure the door is closing tightly as well. Also check your hinges by lifting up on the end of the door while it's open. if it moves up and down, the hinges are worn, causing the door to sag on the other end.
good luck
Hitachi 60SDX88BA Convergence IC - How to remove from heatsink
most of those have screws down one side of the heatsink going into the PC board and other models you have to unscrew the ics through the fins on the heat sink.
Bialetti Moka Express 6-Cup Coffee Maker Logo
Top Bialetti Coffee Makers & Espresso Machines Experts
Pierre Laplante
Kolbrun...
Ross Keen
Are you a Bialetti Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
