Samsung HT-Q100 System Logo
Posted on Nov 20, 2010
I have Samsung HT Q100, and the CD/DVD player will no longer load or unload CDs. Is there a way to fix this on my own?
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Nov 20, 2010
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
0
Helped
846
Points
13
No refer to service technicians only technicians can solve your problems
tip
Remove Regionalisation
Hi All
After having my HT-Q100 repaired by an official Samsung repair centre, I was unable to play any DVD's - even UK ones!
So I phoned Samsung, they said I should return it to the repair centre for it to be fixed.
I couldn't be bothered to waste time on this yet again, so I logged onto Moneysavingexpert.com and found that you can remove regionalisation on DVD players and it's totally legal!
Therefore the following instructions are for removing the regionalisation on the Samsung HT-Q100 so you can play any DVD's! I've just carried this out and it's fixed the DVD problem and can once again play DVD's!
1. Remove disc from tray.
2. Switch off player and unplug from mains.
3. Wait 30 seconds, then reconnect mains.
4. Turn on player with remote. Wait for player to finish loading and display 'no disc'.
5. Press enter on remote. (There will be no on-screen response.)
6. Press 8, 4, 2, 6, 9 on the remote. (There will be no on-screen response.)
7. Press enter on the remote. Player will automatically shut off.
8. Turn player on.
9. turn off.
10. Turn player off then on again.
11. Player is now region-free.
The above was courtesy of the link at: http://www.videohelp.com/dvdhacks/samsung-ht-q100/7502
Qubix
Hi my ht-q100 dvd player not working saying there is no disc even if the disc is inside
Often helps to blow in the hole where the disc goes. Blow hard a few times then try disc again.
I currently have a DVD in and it won't eject. I have a Samsung HT-Q100 System
Turn off the DVD player completely. You MAY have to turn off the tv too. Let sit until you count to fifteen! Turn back on, tv first, then DVD player. You should be able to eject the disc then.
7helpful
How can I make Samsung Home Theater HT-TWZ312 DVD Region Free
there is no region hack for.......
but please try the following code may be works>>
8. Turn player on.
9. Turn off.
10. Turn player on then off again.
Thanks for using FixYa.
Samsung HT-Q100 - Changed Battery on TV remote control
Just try to clean your remote,this the common problem of dirty contacts of remote it plays a certain unit but to the other won't play.Just open it take a toothbrush with an alcohol brush the remote control board,and dry it for 1minute and close it back then check if working..
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
2answers
Multi region player
DVD players come out of the factory region locked. You can either buy an player that does not have a set region (you can only get these online) or you can unlock the DVD player on a computer using software.
Samsung ht q100
No it does not. It will upscale regular DVD's to HD resolution, but that's an electronic trick. You'll need to buy a BluRay player to watch high definition discs.
The HD-DVD standard has been abandoned by Toshiba, so the Sony players are the one's to look for.
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
