Question about Kaz 3300 Humidifier
Fan blades are dirty how do i clean them? - Kaz 3300 Humidifier
Posted by louolleo on
Kory Ronning
    New Friend:
  • 60 Answers
You have to pop the cover off of the top if there are not screws holding the cover on then it should pop off with a screwdriver or you can use compressed air in a can that they sell in stores for cleaning computers
Posted on Nov 20, 2010
Humidifier light goes on. Fan does not work after cleaning it.
Humidifier Fan Not Working - Repair Parts - RepairClinic.com
www.repairclinic.com/RepairHelp/...Fix...Humidifier/...---/Humidifier-fa...
Most Frequent Causes for Humidifier fan not working. For the most ... If the fan blade does not spin freely, replace the blower motor. If the fan blade spins freely, ...
How to Fix a Humidifier ' HomeTips
www.hometips.com/repair-fix/humidifier-doesnt-work.html
Aug 14, 2014 - Repair humidifier problems yourself with this expert, step-by-step ...6Lubricate the fan motor bearings with a couple of drops of light oil if the ...
Troubleshoot and Repair a furnace mounted Humidifier
www.instructables.com/.../Troubleshoot-and-Repair-a-furna...
InstructablesThis instructable will explain how to diagnose and, hopefully, repair a broken ... to flow through the water panel of the humidifier and the humidifier fan turns on. .... drain line was dry, GFI was not tripped, and the fan sounded like it was going so I ... Arduino · Intel IoT · Indoor Gardening · Lighting · Sewing · Parties · Star Wars.
Dec 29, 2015 | Holmes Sunbeam SCM3501 Cool Mist Console...
Clean the fan blades
Don't use a hose, it will rust the motor and bearings.
if the blades are metal, and the unit is detached from the furnace. Try carburator cleaner or brake cleaner - out doors away from flames. Also, rotate so no solvents get to the bearings and wash away he lubricants. The solvent evaporates quickly but it will take a minute so don't be too impatient to get to the next blade.
If they are just dusty, and you don't want to dismount the unit, try some canned air - office stores carry this for cleaning keyboards and such. To get a really good stream, turn the can upside down and spray. The liquid propellant will come out and makes a really good cleaner. It will be cold cold cold as it evaporates and some ice will form if the humidity is high enough.
Effectiveness will depend on what is causing the dust to stick to the blades - oil film, soot from wood/coil/fuel oil and cigarette smoke are difficult.
Mar 10, 2014 | Essick Air MA1201 Moist Air Whole House...
How to clean fan blades on sunbeam humidifier model 1118
I picked up a Sunbeam Humidifier model 1118 for $7 (which was $7 too much) second hand. It wasn't until I got home that I noticed it was filthy-dirty inside...(dirtier than shown in the photos) the reservoir, the bottom tray, AND the fan chamber all needed major cleaning.
A quick Google search told me that the grill is "not removable", and the unit is "not user serviceable". Companies do this/say this for two reasons:
a) They want you to throw it away and buy a new one, landfills and plastic filling our oceans be darned
b) They want to protect themselves from lawsuits, should someone injure themselves servicing their product (or in this instance, cutting their fingers off on the fan blade).
Imagine if all of that design know-how was put into making the product serviceable, cleanable, and long-lasting, rather than ensuring it can't be opened or repaired by the average joe.
Me, I've opened and repaired enough gadgets to think differently.
You CAN remove the grille.
Carefully insert a series of flat-head screwdrivers between the grill and the body a few inches apart, wedging the grill edge away from the body.
There are slits in the body (see photos) that will allow you to get under the grill edge and pry it right out when enough of it has been detached from the anchoring groove.
But be gentle while you're doing it.
The Grille is plastic and flexible; it will bend, but if you use too much force you will damage either the grill or the body.
The photos also show how the grill is anchored to the body - via a groove in the grille edge.
You can put the grille back after cleaning the blades and fan chamber much the same way; pressing down, and if required: prying the side of the grill inwards with a flat head screwdriver.
Mine snapped right back into place with a bit of downward pressure.
e766f363-7859-4f48-aa12-957dce77dc74.jpgclean-fan-blades-sunbeam-humidifier-gt2v12ze2wx14lgcssczfxw0-1-2.jpgclean-fan-blades-sunbeam-humidifier-gt2v12ze2wx14lgcssczfxw0-1-3.jpgclean-fan-blades-sunbeam-humidifier-gt2v12ze2wx14lgcssczfxw0-1-4.jpgclean-fan-blades-sunbeam-humidifier-gt2v12ze2wx14lgcssczfxw0-1-5.jpg
Jan 22, 2012 | Sunbeam Humidifiers
HUMBBLFP1218-A pulls water from the element and it
This Humidifier pulls air from outside the humidifier through the fins of the housing and the fan pushes the air through the element and into the duct. At least, that is what it is designed to do. If the element is clogged or worn and/or if the water distribution tray (located between the top of the element and the water solenoid) is dirty/clogged, it will prevent the humidifier from doing its job.
In your case, it sounds as if the water is pushed into the fan blades which indicates the air is flowing in the opposite direction.......the air in your ductwork is overpowering the force of the fan. At this point, you should check to make sure all supply registers for this system are open and onobstructed. Check your humdifier element and distribution pad for cleanliness/integrity. I say "integrity" because in time, the element will begin to fall apart. If all this fails, you should have a reputable company inspect your humidifier and ductwork static.
Without being there with toolbox in hand, I hope you find this information very helpful moving forward. :-)
Mar 25, 2010 | Carrier LFP Humidifier
I have a Cool Mist V3500 humidifier. The fan
TRY POURING IN SOME WHITE DISTILLED VINEGAR AND RUNNING IT. THE VINEGAR LOOSEN UP ANY SCALE AND JUNK. AFTER RUNNING UNIT FOR AWHILE, DRAIN OUT ANY REMAINING LIQUID AND ADD DISTILLED WATER OR FILTERED WATER. RUN UNIT AGAIN. THEN DRAIN OUT ANY LIQUID. NOW THE UNIT SHOULD WORK AS NORMAL. IN THE FUTURE, TRY USING DISTILLED WATER OR FILTERED WATER.
Dec 13, 2009 | Vicks Cool Mist V3500 Humidifier
I can't remove the grill above the fan so I can clean the blades
I have a Holmes cool-mist One-Touch Humidifier, and you can't reach the blades to clean them, and you can't take the console apart. I finally decided to use two spray bottles and clean and them rinse the Humidifer while holding the console upside down and over a sink. The one bottle you could fill with any mild cleaner plus a lot of water to dilute the cleaner. Maybe dishwashing liquid (not the dishwasher stuff), or a little bit of ammonia, or rubbing alcohol, or vinegar. Spray that on the blades while the machine is upside down, and a lot of sooty dirt drips out. Then rinse with another spray bottle full of plain water. Leave the console upside down on a towel to drip-dry. This is also how you can clean silk flowers that collect dust.
Mar 07, 2009 | Holmes Products Cool Mist HM3500...
Broken fan blade on the 697400 humidifier
Hay Richard -- Little suckers spin to fast for gluing. Take the fan blade off , mark one side before you remove it ex: put an x on the side that is facing the wall. Take blade to a Johnstone supply house. Should be one near you somewhere, they are national. The guys there are usually very good at matching up fan blades. Make sure you keep the one you have with the mark on it. When you get home install the new blade the with the side out that was on the old blade. Hope that helps
Mar 05, 2009 | Bemis 697 400 Humidifier
The humidifer on the Sunpentown SH-1500 heater
what country are you in... winter time is low humidity to begin with.
Robert
Jan 06, 2009 | Sunpentown 1500W Heater Fan Humidifier...
How to clean up?
the best way to clean the fan blades is to take like a paint brush or some type of brush and clean it that way. there isn't a way to take that apart. if you try to it can be difficult to put back together. if you have any other questions please let me know
Dec 29, 2008 | Bionaire Humidifier BCM657U Humidifier
Noise when fan runs.
try cleaning the fan blades
dust/debris build up unbalances the fan and wears the bearings out
oil will only cure the problem for a short while - best option is to relace the fan
Nov 18, 2008 | Humidifiers
Kaz 3300 Humidifier Logo
367 people viewed this question
Top Kaz Humidifiers Experts
ray gallant
Tom Chichester
Are you a Kaz Humidifier Expert? Answer questions, earn points and help others
