IBM TravelStar 40GN 40 GB Hard Drive Logo
Posted on Nov 20, 2010
Hello, I am using IBM travelstar USB 2.0 and I need it's drivers for Windows XP. Earlier we would use it on Windows 98 but now the CD is no more compatible for Windows XP. Please Help.
1 Related Answer
Anonymous
  • Posted on Jul 19, 2008
SOURCE: Cannot Open when connected
I connect harddrive IBM Travelstar 20 GB Model IC25N020ATCS04-0 (made in Thailand) to PC via USB port but cannot open ,LED is light .How can I do , I have no driver.Pls. help me.
1helpful
2answers
Connect external hard disk IBM travel star 80GB USB port 2
Unless it's windows 98 you don't need a driver. If your computer can't see it, it's probably broken. Try plugging it in to another computer and see if it can see it
1helpful
Flash drive isn't being recognized need to back up
Regarding on your problem, in windows xp and up version of windows operating system, plug and play device is easy and no need to install its drivers manually cause the computer will automatically install its drivers. But in the case of Windows 98 you have to install your USB Driver manually in order to be recognize by the system. So my recommendation please insert the CD driver or load the driver of your USB and run the setup.exe to install the USB Driver.
Thanks
1helpful
Installing Buffalo Webcam on Mac
Check here for MAC compatible cameras.
Manufacturer/Model Driver version Platforms Meets requirements
3com Home Connect 6.6.4 Windows 2000, Me, 98 Yes
Apple iSight (Firewire) Firmware 1.0 Mac OS X (Pantder) Yes
BTC PC 380 Intel 3.20.1001.0 Windows XP Yes
Creative WebCam Go Plus 1.0 Windows XP, Me, 98 Yes
Creative WebCam (WDM) 1.0.11.131 Windows Yes
D-Link USB WebCam(DSB-C100) 0921 Windows XP, 2000, Me, 98Mac 9.2 and 9.1 Yes*
IBM Ultraport Camera 2 Most Current Windows 2000 Yes
Intel Deluxe PC Camera 1.0 Windows XP, 2000 Yes
Intel Easy PC Camera 1.0 Windows XP, 2000, Me, 98 Yes
Intel PC Camera CS 110 6.0.0.62 Windows X Yes
Irez Kritter USB 1.02b4 Windows 2000, Me, 98,Mac 9.1 Yes*
Irez StealtdFire 1.2 Mac 9.2, 9.1, 9.0.4 Yes
Logitech ClickSmart510 7.0.0.1221 Windows Yes
Logitech QuickCam traveler 6.0.1 Windows 2000 Yes
Logitech QuickCam Web 6.0.1 Windows 2000 Yes
Logitech QuickCam Express 6.0.1 Windows 2000 Yes*
Logitech QuickCam Pro 3000 6.0.1 Windows XP, 2000, Me, Mac 9.2 and 9.1 Yes
Logitech QuickCam VC Windows - 4.1.5 Macintosh - 2.1.2
Windows 2000, Mac OSX, 9.2, 9.1, 9.0 Yes
Logitech QuickCam Zoom 8.0.3.1110 Windows XP Yes
Orange Micro iBOT Pro Firewire 4.10.22 Windows 2000, Mac OS X and 9.2 Yes
Veo Stingray 5.0.0.0 Windows XP, Me, 2000, 98 Yes
Hope this helps. Bud
21helpful
5answers
Icam 320 driver
For the Manual and Driver for Windows 98/ME/2000/XP
http://www.visioneer-europe.com/primascan/support/icam320.htm
Product Specification 100k Pixel / Colour CMOS Sensor
USB Interface with 2 metre cable
Manual Focus - 2 inches to infinity
Field of View Angle - 45°
Tilt Angle: Up to 20.4° / Down 20.4°
I/F: Snapshot button and LED Status indicator
Frame Rate: Up to 30 fps @ CIF, 5.12 KB/sec USB Bandwidth
Still Image Capture: 160 x 120, 176 x 144, 320 x 240, 352 x 288
Video Recorder: 160 x 120, 176 x 144, 320 x 240, 352 x 288
S/W Driver: WDM & TWAIN for Win 98 & 2000
Compatible with Windows Millennium
Includes Built-In Microphone
System Requirements USB Port
Windows 98/2000/ME/XP
233 MHz Pentium Processor with MMX or faster
32MB RAM or greater
800x 600 / 24-bit display
CD-Rom driver
Windows compatible sound card with speakers
Internet Service Connection
1helpful
3answers
Lost Master Harddrive Password
First chek in BIOS if exsist CHANGE HDD PASSWORD if not use download somwhere HIREN BOOT CD v8.2.Let me know if u got help;)
My Fujifilm digital camera is connected to my computer, but the removable disk does not appear when I open "My Computer" in Windows. I have a FinePix camera and have installed the software.
If the removable disk does not appear when you open "My Computer" in Windows, it is possible that the USB drivers are not installed correctly. Update to the latest version of FinePix Viewer (including the USB drivers). To update FinePix Viewer, you must have the software from the CD-ROM bundled with the product (Utilities for FinePix) already installed. As an alternative method to updating the software, you can also reinstall the USB drivers. The USB drivers can be reinstalled by installing the software from the CD-ROM again. If the removable disk is still not displayed after the above measures have been taken, check the following: Windows system checks 1. You should be using Windows 98, Windows 98SE, Windows ME, Windows 2000 or Windows XP. 2. The Windows XP USB drivers are supported as standard system drivers but are only compatible with Software for FinePix versions 2.0 or later. If you are using an earlier version of the CD-ROM, an update to FinePix Viewer is required. 3. The software cannot be installed properly from "Scanners and Cameras" in the Control Panel. Digital camera checks 1. Check that the digital camera can play back images on its LCD monitor. 2. On digital cameras with the PC Camera function, select "DSC" as the USB setting. (Refer to the Owner's Manual for your camera for information on specifying the camera settings.)
Top IBM Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
