Question about Williams (5009622) Ceramic Gas Wall Mounted Panel Heater
I just installed a new gas wall furnace and the gas smell is very strong. I checked all of the connections for leaks and they're all good. Do I need to turn the pilot down? If so, how do I do that?
Posted by jodi5burr on
4 Related Answers
Therinnaiguy
Chandler Ede
  • 1420 Answers
SOURCE: my new wall furnace was working fine, shut off now
Jump the two thermostat wires together to test the thermostat. Next, jump the terminals at the heater to test the thermostat wires. If the unit fires, you have found your problem. If it does not, you will need to turn the thermostat to the highest setting and check for 24 volts at the gas valve. If yes, bad gas valve, if no, bad transformer.
Posted on Jan 30, 2010
Anonymous
SOURCE: I have Wiiliams direct vent wall furnace. I smell
Dear Alex191: I am shocked and amazed that the Williams heater company is STILL knowingly and willingly selling faulty direct vent gas heaters. My problems took place in 1988! I bought a 30,000 BTU Williams DIRECT VENT from The Home Depot. I took the time to remove window sashes and run gas line to the Williams heater that I had placed in the window aperture. I was glad to finally have heat and be able to heat the area of the house where I stayed. Then I began to smell gas when the Williams was OFF. I traced it to the area where the pilot light gas tubing entered the combustion chamber. I removed the Williams unit and replaced it with an identical make and model and the SAME THING HAPPENED!!! I sat on my bed and almost cried. I had the gas company come out and they labled the problem as a "fuzz leak". The warranty repairman came out and had no idea what to do. Tightening the retaining nut did nothing. I called Williams and even back then they said that they were aware of the problem. They called me back and wanted to send me a part and asked me, "Can you work on it?" I returned the Williams and bought a Perfection-Schwank CONSOL heater that burns the air in the room and vents horizontally to a 4 inch vertical gas vent and was very satisfied with it. When they went out of business I bought an "Empire" brand gas heater. I don't know if I'll ever buy another direct vent heater from anyone. I will be glad to write an affidavit should you decide to suit the Williams company.
Posted on Dec 14, 2010
Anonymous
SOURCE: Williams 3003622 Wall Mounted 30,000 BTU The pilot
I'm having the same exact problem... At first we thought was the vent... but the way the flames goes out... it seems that there is "not enough oxygen" more than "blown out by the wind"... right after both main & pilot goes out, I can't even light any external flame inside the chamber... and it doesn't feel like the outside cold air coming in... it just feel like there is some sort of gas in the chamber that's so strong, it prevents flame... and the only thing I can think of is that it doesn't have enough oxygen, but too much natural gas, and flame can't sustain.
Posted on Dec 16, 2010
walterkunesk
Wally Bald Guy
  • 683 Answers
SOURCE: My new gas wall furnace
is it a standing pilot light?
Posted on Mar 11, 2011
Williams wall heater 2509622. How do I keep the pilot on? It tends to turn off after it reaches the desired temperature.
WILLIAMS 2509622 OWNER'S MANUAL Pdf Download.
www.manualslib.com > Brands > Williams Manuals > Furnace > 2509622
2509622; 2539622; 2559622; 3509622; 3539622; 3559622; ... WHAT TO DO IF YOU SMELL GAS: ... Williams furnace co. direct-vent wall furnace owner's manual (24 pages) ... Caring for Your Furnace ............24-25 Locating Wall Furnace and Thermostat ........6-7 Learn how to keep your new Williams Furnace operating.
How to light Heater or Furnace Pilot Light Gas Pilot of ...
? 5:01
https://www.youtube.com/watch?v=FZVQmKTYTTg
Oct 25, 2013 - Uploaded by 3p0cHx
How to light a gas pilot for a heater or furnace of the Williamstype. This is a general guide and is not ...
[PDF]Monterey Installation Instruction Manual - Home Depot
Dec 08, 2015 | Williams Heating & Cooling
How can I diagnose & fix a fuel leak in a 2005 dodge caravan?
check to see if the fuel filter is leaking at line connections as the filter is on top of the tank. if so replace the filter. check the seal for the tank unit that seals this to the tank. being this new it should be good its more likely the fuel filter.
Sep 07, 2014 | Cars & Trucks
Fuel tank leak in 1997 Subaru Impreza L
your strong smell of fuel was in side the car , under the hood . ? now check to see if here is any gas leak under the hood --- gas line , filter. check under the car for any leak , or by the gas tank . it might be just sweating, make a good check , re ply me what you find
Aug 02, 2010 | 1997 Subaru Impreza
My 2005 Chevy Impala smells gasy when ever started and sometimes after idling for awhile.
SMELL GAS YOU NEED CHECK ALL FUEL LINES UNDER THE HOOD IN THE ENGINE COMPARTMENT.IF GAS IS STRONG UNDER HOOD YOU DONT SEE LEAKING FUEL LINES.YOUR FUEL RAIL FUEL INJECTORS LEAKING OR FUEL PRESSURE REGULATOR O - RING OR DIAPHRAM LEAKING GAS.IF FIND NO LEAKS UNDER THE HOOD CHECK FUEL LINES UNDER CAR FROM ENGINE TO FUEL TANK FOR LEAKS.IF ALL IS GOOD YOUR EVAPORATIVE CANISTER SOAKED WITH GAS OR YOUR EMISSION EVAPORATIVE SYSTEM NOT WORKING. DEALERSHIP HAS TO CHECK AND FIX.
Jul 03, 2010 | 2005 Chevrolet Impala
There is a strong smell of gas from my cooker, pipe from cyclinder to cooker appears ok , new world 55wlg
Do not light anything if you are smelling gas. Make up a soapy solution in a spray bottle and apply to all connections and look for bubbles. Most common place to leak is hook-up at cylinder and hook-up at cooker. If you can't find the leak and continue to smell gas, do not use it. Also make sure your cylinder is not empty.
May 15, 2010 | New World 55WLg Gas Kitchen Range
We had our furnace repair turn on our Aprilaire 760 last summer. It gives off a very strong smell similar to an air freshener. We'd like that to be less in intensity. Furnance company says it's just fine....
I hope this helps you, have the repair person check to see if a furnace filter air freshener was installed at your last furnace check up without your knowledge. Also checked all wall and or floor registers to make sure the source of smell is not coming from them, it may be circulating though the duct system.last thing is to replace media pad in humidifier along with furnace filters, if you have air cleaner wash filters with hot water and baking soda, wipe & let dry before re- installing them. Your repair person may have use a strong smelling cleaning solution in humidifier that is now circulating though out your home, good luck.
Jan 24, 2010 | Aprilaire 700 Humidifier
When I first turn on my air-conditioner (it's attached to the furnace) a smell of raw gas comes through the vents. My air conditioner is a Lennox.
Obviously you have a leak in/at/near the furnace. Most gas companies will come out at no cost and do a leak search. Strongly recommend you do that.
Aug 23, 2009 | Heating & Cooling
Goodman gms9090 furnace
Based on your description I would guess that there is a "leak" somewhere between the gas valve and the actual fire. Use soap bubbles to check the connections at the gas valve. Also check the gaskets in the Gas valve the same way. Lastly there may be a cracked or misaligned burner causing the "leak". Best of Luck!
Jan 29, 2009 | Goodman GDS80703ANA Open Flame Mid-Size...
Smell gas through vents when furnace is running
I would strongly suggest a carbon monoxide detector first. Also your gas provider should do a free leak check. This is nothing to play with.
Dec 02, 2007 | Heating & Cooling
Williams (5009622) Ceramic Gas Wall Mounted Panel Heater Logo
489 people viewed this question
Top Williams Heating & Cooling Experts
Paul Carew
Muntejaya Ginting
Muntejaya Ginting
Vincent G
Vincent G
Are you a Williams Heating and Cooling Expert? Answer questions, earn points and help others
